Author Topic: PSI gauge  (Read 1518 times)
cashflowdub
PSI gauge
« on: August 21, 2007, 11:07:14 PM »
putting a psi gauge on my penstock just before my turbine is what i would like to do
is there any special pvc fittings available or does it need to be rigged up and i have a gauge but i dont think it is the right one so whic hones should i be looking at
« Last Edit: August 21, 2007, 11:07:14 PM by (unknown) »
RP
Re: PSI gauge
« Reply #1 on: August 21, 2007, 09:25:14 PM »
What pressure do you expect (or what is the head) and what size is the pipe?
« Last Edit: August 21, 2007, 09:25:14 PM by RP »
cashflowdub
Re: PSI gauge
« Reply #2 on: August 21, 2007, 09:27:44 PM »
the pipe will be 4 inch reduced down to another size(unknown yet) for my nozzle and i havent got my head figured out yet becuase i dont know how much penstock i tend to run i just want to know how people are setting there gauges up on there systems
« Last Edit: August 21, 2007, 09:27:44 PM by cashflowdub »
chainsaw
Re: PSI gauge
« Reply #3 on: August 23, 2007, 04:06:05 AM »
You are correct to want a pressure gauge just before entering the turbine. I have a small hydro unit with a turgo runner. I have found the gauge invaluable for trouble shooting. Your static and dynamic pressure changes will alert you to-air in penstock, intake restriction, and nozzle obstruction.
« Last Edit: August 23, 2007, 04:06:05 AM by chainsaw »
spinningmagnets
Re: PSI gauge
« Reply #4 on: September 07, 2007, 05:03:27 PM »
Just to help you determine the gauge range you'll need, measure the elevation between the water level in your penstock and the turbine. You should get about 19 PSI per 10 feet of head (if I remember correctly).
"Close" only counts in shaving and nuclear weapons. -Lyndon Johnson
« Last Edit: September 07, 2007, 05:03:27 PM by spinningmagnets »
