Author Topic: Hooking up LED lamps to 12 volt source  (Read 3266 times)
« on: November 12, 2007, 07:03:24 PM »
 Some of my LED lamps use 6volts(4AA alkaline
batteries, some only require 2AA batteries for
each lamp now can I simply for example put 2 LED
lamps each requiring 6 volts in series to a 12
volt battery.....(Duh!) I know it might sound
dumb but I'd hate to ruin $16 worth of lamps
by doing it.
  Thanks for taking the time to answer this
anyone.
  Any reason for making your own set of lamps
just to save money....or is it mostly for the fun
of it?
            ( :>) Norm.
« Last Edit: November 12, 2007, 07:03:24 PM by (unknown) »
Re: Hooking up LED lamps to 12 volt source
« Reply #1 on: November 12, 2007, 03:35:16 PM »
« Last Edit: November 12, 2007, 03:35:16 PM by wooferhound »
Capt Slog
« Reply #2 on: November 13, 2007, 03:13:53 AM »
Very like the calculator that Woofer posted, but this is the one I use..
http://led.linear1.org/led.wiz
« Last Edit: November 13, 2007, 03:13:53 AM by Capt Slog »
Electron Skipper
« Reply #3 on: March 08, 2008, 11:17:38 PM »
Actually a better solution to Norm's situation is to be found here:
http://www.zetex.com/3.0/appnotes/apps/an44.pdf
Downside is they are an SOT-23-5 configuration so sharpen your soldering iron tip.
Digikey actually carries the 2 items mentioned in the application note.
http://www.zetex.com/3.0/pdf/ZXSC300.pdf
http://www.zetex.com/3.0/pdf/ZXSC310.pdf
Are their datasheets, but the figure 3 circuit of the application note provides the means of lowering the supply voltage to the chips, and with efficiences better than 85% are well worth looking at.
« Last Edit: March 08, 2008, 11:17:38 PM by Electron Skipper »
Electron Skipper
« Reply #4 on: March 08, 2008, 11:19:57 PM »
I forgot to add that these are less than a buck each with price breaks at 25 units.
« Last Edit: March 08, 2008, 11:19:57 PM by Electron Skipper »
commanda
« Reply #5 on: March 09, 2008, 01:50:29 AM »
of it?
A 12 volt battery used in an RE situation, could be anywhere between 11 and 15 volts.
Online calculators are all well and good, but don't assume a 12 volt battery is 12.000 volts.
I wrote a mini-thesis on this subject a while back; the last part is here:
http://www.fieldlines.com/story/2007/10/31/848/94375
but has links to the first 4 parts.
I build all my own stuff on the theory that if I built it, I can fix it.
Generally speaking, lamps designed to run on AA batteries won't handle the much greater voltage range of a real RE situation.
« Last Edit: March 09, 2008, 01:50:29 AM by commanda »
