Author Topic: Had to Laugh!  (Read 333 times)
WXYZCIENCE
Had to Laugh!
« on: April 07, 2006, 12:57:07 AM »
Here is a picture of a Unite Motor I found in a surplus store.
Tested it at 850 rpm and I got 12v at 6 amps. The first time I ran across over unity motors. HaHaHa. I got a good deal on them, guess the inventor vanished and they had to sell off the stock. I got the whole pile! :: Now for real,I checked the manufactures site, they are a electric bike motor generators rated 150 watt 18 volt  10 amps. Joe
« Last Edit: April 07, 2006, 12:57:07 AM by (unknown) »
Re: Had to Laugh!
« Reply #1 on: April 07, 2006, 06:46:34 AM »
 Joe,
   Are those brushless? I'd laugh too if I ran
across a deal like that...Darn! Some people have
all the luck ! The whole pile ...Huh !
  If you could see me up close....a tear or two
in my eye....LOL ?
                    ( :>) Norm.
« Last Edit: April 07, 2006, 06:46:34 AM by Norm »
Re: Had to Laugh!
« Reply #2 on: April 07, 2006, 08:34:17 AM »
No, probably not brushless. At least, mine isn't. It's a 24V version from an electric bike. Mine is useless as a generator though, requires 1500+RPM, from memory.
I see these motors just about everywhere. Cheap Chinese stuff, but then, if the price is right, I won't complain :)
You plan to make a windgenny out of them, or why else have you bought a pallet of these? I can think of some applications, they're easy to mount too. Mine have 608 ball bearings, IIRC. 4 carbon brushes.
Peter.
« Last Edit: April 07, 2006, 08:34:17 AM by dinges »
WXYZCIENCE
Re: Power in=Power out
« Reply #3 on: April 07, 2006, 11:37:13 AM »
The genny will have to be geared up of course. I can make notched belt pulleys easy, and I have lots of belts. Power in = Power out - losses. Joe
« Last Edit: April 07, 2006, 11:37:13 AM by WXYZCIENCE »
« Reply #4 on: April 08, 2006, 12:46:16 AM »
I'm not getting it. Never mind, it seems to be happening a lot lately.
Peter.
« Last Edit: April 08, 2006, 12:46:16 AM by dinges »
« Reply #5 on: April 08, 2006, 05:38:06 PM »
"Unite", like 'unity', or 'over-unity'.
It takes 2 motors to work. Run one from the battery, use it to run the other as a generator charging the battery.
Now (my favorite part) connect an inverter to the battery so you can use all the extra power made in your home!
With a hundred of these motors, he can supply the electricity needs of a small town!
Using the proper ICs and a big flux capacitor, it doesn't even need batteries!!!
Why didn't I think of it sooner!  I'm going to be rich for sure!
And I'd be quite happy finding a motor like that.
« Last Edit: April 08, 2006, 05:38:06 PM by ghurd »
mutley
« Reply #6 on: April 08, 2006, 05:45:42 PM »
would you be ever kind enough please to explain how you make notched pulleys as i am finding it difficult to find suitable sizes
« Last Edit: April 08, 2006, 05:45:42 PM by mutley »
« Reply #7 on: April 08, 2006, 08:05:32 PM »
<slamming on forehead>
Thanks.
But be careful. You and I might realize it's tongue-in-cheek. But I don't want to know how many people are running about now, trying to find two of these motors and solve the energy problem. :/
Peter.
« Last Edit: April 08, 2006, 08:05:32 PM by dinges »
« Reply #8 on: April 08, 2006, 08:30:49 PM »
Hi Peter!
Anyone who thinks this is a new or actually workable idea, tell them I will sell them the parts!
All the parts... except the flux capacitor!
Good point.
It does NOT work.
« Last Edit: April 08, 2006, 08:30:49 PM by ghurd »
WXYZCIENCE
Re: Notched Belt Pulleys
« Reply #9 on: April 08, 2006, 11:47:26 PM »
The machine in this Picture is my wxyz cutter built 2004. All of it's parts were built  by my previous machine. And the previous machine was built using a drill press. I use a dynacad program to build up my parts. This picture is of a dual 34 ceramic magnet genny being cut on the rotary table. For notched belt pulleys, I just tell the machine number of teeth and diameter. I don't know how I did without this machine before.
The X and Y beds have dual acme thread 4000 steps per inch with automatic backlash compensation.The Z has 4 acme thread and 4000 steps per inch.Thank for your interest. Joe
« Last Edit: April 08, 2006, 11:47:26 PM by WXYZCIENCE »
bob g
    • microcogen.info
Re: Had to Laugh!
« Reply #10 on: April 14, 2006, 10:12:41 PM »
make a plywood disc the size of gear you want,
wrap a release coated cog belt around it, and pour resin to form the teeth.
i have seen gears made for lathes done this way,
bob g
« Last Edit: April 14, 2006, 10:12:41 PM by bob g »
WXYZCIENCE
Re: notched pulley belts
« Reply #11 on: April 15, 2006, 06:03:39 PM »
Yes Bob, I have made them like that, planetary design also if you flip the belt inside out and pour the resin on the outside you can make not to shabby internal cogs. I also made some silicone gears for silent servos. Joe.
« Last Edit: April 15, 2006, 06:03:39 PM by WXYZCIENCE »
