"but for reasons i wont go into i have an open top tank"
Well don't go into it if you don't want, but I have a question on it. When you heat the water and you have an open tank will you have humidity problems?
Just thought I'd ask. To keep static shock to a minimum here I place a coffee can of water behind the wood burner. It does not get too hot, but enough to put some moisture back into the air and we now seldom get static shocks like we used to.
So if you have an actual open tank, geuss that's what you meant, and you heat water to
near 150F as you say, is humidity and evaporation going to be a problem for you?
My water near the wood burner never gets near that hot, and it does evaporate. Don't remember how often I fill the coffee can normally. Have not needed the water can yet this year, just now really starting to need a fire.
Just thought I'd mention the humidity in case you hadn't thought of it and do have an open tank.
