Author Topic: Battery Wiring  (Read 1797 times)
Ampman354
Battery Wiring
« on: May 15, 2006, 05:07:48 AM »
Each battery is 6 volts and 530AH's  would this get me 12volts?.....i know this seems stupid to the vets on this board and yes i searched the board for more info and the pics on the Otherpower battery section did fully help....helped but not enough.
« Last Edit: May 15, 2006, 05:07:48 AM by (unknown) »
commanda
Re: Battery Wiring
« Reply #1 on: May 14, 2006, 11:51:45 PM »
No.
Join all the left side positives together. Vertically.
Join all the right side negatives together. Vertically.
For each horizontal pair of batteries, join the 2 free terminals in the middle together.
Ascii art.
pos        neg
Hope that makes sense.
« Last Edit: May 14, 2006, 11:51:45 PM by commanda »
cjdock
Re: Battery Wiring
« Reply #2 on: May 15, 2006, 05:47:22 AM »
Here is my 6 v battery set up as a 12 v system:
« Last Edit: May 15, 2006, 05:47:22 AM by cjdock »
wpowokal
Re: Battery Wiring
« Reply #3 on: May 15, 2006, 05:47:49 AM »
look here!
http://www.solarexpert.com/Batteries/batchart.html
regards
Allan down under
« Last Edit: May 15, 2006, 05:47:49 AM by wpowokal »
Ampman354
Re: Battery Wiring
« Reply #4 on: May 15, 2006, 09:13:29 AM »
whats the total Amp hours on yours cjdock
and any suggested configurations on my battery bank each battery will be 6v@530ah and i want it to be 12v amp will follow it having to be 12v.  There will end up being 16 batterys
« Last Edit: May 15, 2006, 09:13:29 AM by Ampman354 »
cjdock
Re: Battery Wiring
« Reply #5 on: May 15, 2006, 01:02:08 PM »
My set-up is actually half of the pic I drew. I have only 4 batteries. My batteries are 201 amp/hour each so with each pair in series, then paralled to each other, I have 400 amp/hours @ 12volts. That link the other person provided is very helpfull to me.
« Last Edit: May 15, 2006, 01:02:08 PM by cjdock »
powerbuoy
Re: Battery Wiring
« Reply #6 on: May 15, 2006, 02:45:49 PM »
How about this one ...
Powerbuoy
« Last Edit: May 15, 2006, 02:45:49 PM by powerbuoy »
Re: Battery Wiring
« Reply #7 on: May 15, 2006, 03:30:13 PM »
Powerbuoy;
Nice, accurate diagram and a very small file to do it, 2.2k and it conveys the information perfectly.
My old 12 volt setup was exactly like that.
12 T105 Trojan 6 volters seriesed in pairs then those pairs paralleled. 12 volts at 1350 AH. If I recall right they are 225 AH at 6 volts.
Now it is split into a 24 volt bank at 450 AH and a 12 volt bank at 450 AH.
Just backing up your schematic with real world experience.
« Last Edit: May 15, 2006, 03:30:13 PM by TomW »
powerbuoy
Re: Battery Wiring
« Reply #8 on: May 15, 2006, 04:23:25 PM »
Thanks a lot!!!
« Last Edit: May 15, 2006, 04:23:25 PM by powerbuoy »
Re: Battery Wiring
« Reply #9 on: May 16, 2006, 12:32:56 AM »
If it was me, I would pull the negative from the top of the diagram.
« Last Edit: May 16, 2006, 12:32:56 AM by wooferhound »
ruddycrazy
Re: Battery Wiring
« Reply #10 on: May 16, 2006, 03:03:32 AM »
Well powerbouy could be in the southern hemishere so the negative should be on the bottom
« Last Edit: May 16, 2006, 03:03:32 AM by ruddycrazy »
Re: Battery Wiring
« Reply #11 on: May 16, 2006, 04:55:51 AM »
Woof;
Actually, I pulled my power from the middle of both sides in an attempt to keep it balanced. 12 volts can pull a lot of current so it seemed wise at the time.
T
« Last Edit: May 16, 2006, 04:55:51 AM by TomW »
