There was a post sometime back about the direction the blade spins and clearance between the prop and the pole. I never gave it much thought and have run the props in either direction. A couple times it wasn't by choice but by mistake in carving. I really never gave it much thought.
I just finished rebuilding an old aermotor tower and got it up which will need a larger offset to get the clearance I need. In the past I've always used the 5 inch rule, something I picked up while building airplanes. We used composite props and they were fairly flexible but the wood props didn't require as much clearance although I still mounted the engine with the same clearance.
Dan had mentioned a little trick using a bike wheel to see which way the prop should turn to get the blades to pull away from the tower instead of into it during yaw. I decided to try it out. Here is the thing, when it yaws one way it will smack you in the forehead but when it yaws back it bops you in the knees. This occurs in either direction of rotation but in reverse. So, rotation doesn't matter and the clearance has to be built in.
I guess I'll stick to the 5" rule...
Have Fun
