one of my mills is an amtek micro , on it 2 years ago lost 1 set of blades (ripped off ) made of aluminum and 1 of galvanized steel blades to wind speed of 75 mph that I didn't turn on the stop (short)
switch to stall the mill.since then I have been running smaller galvanized blades length 1/4 less and width 1/5 less with no problems.
last week we had a storm around 50 mph and I threw on the stop switch before the winds picked up and it did just that,the problem was mill turned 180 away from wind
and the blades weren't moving so they bent.
Upon further thought my game plan is leave mill alone unless forecasted winds are much greater than 50 mph then I will tilt
the tower down and may try composite fiber blades.
good luck and here's is a quote from a wise very wise man:
> "And if you don't have busted wind turbines, then you live in a poor wind area." (Cris Olson)
hayfarmer
