G- yea, i'll do that next time up weekend after the 4th. then, i'll be able to give a positive blade clearance measurement. i'm almost losing more sleep over the fact that it's shorted, yet not connected to a battery bank right now. just checked the ten-day wind forecast for up there, and 17mph is the highest. i think it can handle that.
since this is my diary afterall, i wanna list some specs i've got so far. may make a good model for someone to follow in the future. maybe not. from the ground up:
footings- 18 x 18 at top, 36 x 36 at bottom, and four foot deep/tall. about 3,000lbs of concrete.
rebar- all welded, mix of mishmash from the shop. guy connections into small "I" beams that go into footings, and welded to the rest of it.
pipe- same for tower and gin. 20' chunks of .156 x 4" pipe. really cheap on salvage pricing.
tower/gin joints- gusseted with 14" long chunks of 1/4" with hole drilled for guy connections. gussets every 20'
tower hinge- 4 x 4 x 1/4 angle welded to 4" pivot pipe. found scrap in shop that nestled.
guys- 1/4 for the top, and 3/16 for lower sets. used one size larger on all thimbles.
mill- has a 6" offset (ctr of blades to ctr of tower) for a 102" blade diameter, roughly following the 4-6% rule. i went with 6% because i figure it's much easier to add weight to the tail.
furling- followed hugh's book to the "t" if i understood it correctly
![Smiley :)](https://www.fieldlines.com/Smileys/default/smiley.gif)
incorporated- a 3% upward tilt on blade mounting to increase tower to blade distance.
motor- fanuc A06B-0355-B755. 3-PHASE 2000RPM 140V 20A 23Nm(stall) 8POLE blt-1997
blade mounting- double stainless round disks 12" x 3/16" sandwiching blades. these mount to a solid block of round ALU that matches the motor's taper shaft. bolted and shear pins. (the one part i didn't make)
blades- 8 pieces of clear fir laminated in a 2pc x 4pc config with offset joints. roughed out with a chainsaw thanks to Oztules! angle grinder with flapwheel to finish rough out, and sanded. one layer of 6oz fiberglass on outer 2/3's wetted with west system. then two more layer of west to get good build-up and fill divits. (small batches with filler). 3 coats of 2-part epoxy paint, then a final rattlecan for uv.
hardwear- all stainless.
wiring- 6/3SO down the tower (80 foot with slack) and to stop switch. then (3) #3's to outside rectifier in a box (50') then, stay with me here, a #6 and two #8's for the pos. off the rect. then a #6, a #8 and two #12's for the neg. so that grip of random (and free) wires goes 65' to the battery bank. all wire was free except for the 6/3SO.
i probably forgot to mention something but figure it's be good to get specs down while they were on my mind.
adam
