Author Topic: ice on blades  (Read 2681 times)
stratford4528
ice on blades
« on: January 18, 2013, 10:26:03 AM »
I decided to shut the turbine down last night because of expected gales. Started back up this morning and the blades are all snow and ice so it wont turn very fast. Is it best to shut it down till it thaws or let it spin and hope it throws the ice off.
tanner0441
Re: ice on blades
« Reply #1 on: January 18, 2013, 04:17:10 PM »
Hi
Depends on the type of turbine and whether there is ice in the stater or not, it could, if it is hard enough damage the windings.
So far we avoided the wind and the snow apart from a slight dusting this time.
Brian
stratford4528
Re: ice on blades
« Reply #2 on: January 18, 2013, 06:21:31 PM »
The stator is totally enclosed which is a problem because it over heats and burns out. But the problem is the ice is on the blades which makes them not an airfoil.  So it turns very slowly
ChrisOlson
Re: ice on blades
« Reply #3 on: January 18, 2013, 07:00:35 PM »
I generally leave them run.  The air moving over the blades makes the ice sublime faster.
Windy11
Re: ice on blades
« Reply #4 on: January 19, 2013, 12:51:04 AM »
Thanks Chris, seems like we just went through this up in Canada. LOL!
Alias: Andy R.
stratford4528
Re: ice on blades
« Reply #5 on: January 19, 2013, 07:24:32 AM »
Just climbed my tower and scraped 2" of ice off the blades.
Re: ice on blades
« Reply #6 on: January 24, 2013, 06:25:18 AM »
20 80 antifreeze  works for a while .
tanner0441
Re: ice on blades
« Reply #7 on: January 24, 2013, 06:49:23 AM »
Hi
If your in the UK Halfords sell some stuff you spray on your car windscreen the night before your expecting frost or snow and it stops it sticking, I think it could be called "The night before".
I don't know who would sell it in the US.
Brian
stratford4528
Re: ice on blades
« Reply #8 on: January 24, 2013, 08:50:37 AM »
Tanner o441.
Thanks for that but I would not want to climb the tower just to do that. It was bad enough having to go up to scrape the ice off. I think I'll leave it running next time.  By the way I'm in Wales.
tanner0441
Re: ice on blades
« Reply #9 on: January 24, 2013, 01:49:16 PM »
Hi
Where in Wales I am in Denbigh.
Brian
stratford4528
Re: ice on blades
« Reply #10 on: January 24, 2013, 02:32:28 PM »
Carmarthenshire
Re: ice on blades
« Reply #11 on: January 25, 2013, 02:32:46 PM »
We generally let ours run thru all conditions except a known/forecast hurricane event.  When we first put it up I would shut it down more frequently.  What I've found is if your getting temps. where it is rain, turning to freezing rain, ...the blades will coat, but it will at least be even.
If, on the other hand, it has been stopped - either because there was no wind prior, or in this case it was shut down due to high winds - I'd favor letting it thaw.  This event is probably past by now, but some of the scariest "whole lot of shakin' goin' on" I've ever seen is when, on rare occasion, you have one or two of the blades loaded up; one or two not.  Couple that with a natural frequency with your tower and you can be running for cover.
~ks
