Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Wind
main shaft and hub study
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: main shaft and hub study (Read 4216 times)
mbouwer
Hero Member
Country:
on:
January 02, 2018, 08:32:22 AM »
The aim is to search for a main shaft design which I also can easily reproduce for windmill friends.
The axle starting point with two bearings 72-35-17 and 62-30-19 mm.
Last Edit: January 02, 2018, 09:35:08 AM by mbouwer
Logged
mbouwer
Hero Member
Country:
Re: main shaft and hub study
Reply #1 on:
January 03, 2018, 05:09:29 AM »
The assembly with the two standard bearings.
Now I want to try out a different idea based on an axis of a front wheel drive car.
Last Edit: January 03, 2018, 05:34:42 PM by mbouwer
Logged
mbouwer
Hero Member
Country:
Reply #2 on:
January 04, 2018, 05:34:54 AM »
Usefull remaining parts after dismantling a front axle.
Logged
Development Manager
Super Hero Member Plus
Country:
Reply #3 on:
January 04, 2018, 02:25:16 PM »
Looks good
Logged
george65
Sr. Member
Country:
Reply #4 on:
January 04, 2018, 07:31:38 PM »
I recently picked up some Subaru hubs to build a garden trailer with.
They have a very convenient mounting point where they attached to the struts that can be bolted or welded to a support. Alternately the assembly could be mounted on a ball joint like original so the thing pivots. The ball joints are sealed and last over 100k Km in road use so I'm pretty sure would not be wearing out in a hurry on a turbine.
The disk slides over the studs which retains them regardless of wether the drive shaft is in place or not.
I don't know if using the shaft to mount the alternator back away from the blades would be an advantage or not but it would certainly allow a good degree of weather sealing.
The tail assembly could be mounted on the sturdy arm that the steering rack mounts to.
Guarantee the supply of Subaru spares isn't going to dry up in wrecking yards due to people building turbines. Threw away about 50 of the things before Christmas because they don't sell a lot which means they don't fail too often .
Logged
mbouwer
Hero Member
Country:
Reply #5 on:
January 05, 2018, 05:31:03 AM »
JW,
Thanks for having me on this forum. OP inspires me.
George65,
Do you mean a hub like this?
Important is how big I can drill a bushing hole of a sufficiently large size through the axle.
This is for the guiding of the rod of the pitch adjustment.
Logged
mbouwer
Hero Member
Country:
Reply #6 on:
January 05, 2018, 05:52:49 AM »
The axle shaped out of the parts I show in Reply #2
Logged
george65
Sr. Member
Country:
Reply #7 on:
January 05, 2018, 08:36:32 AM »
Nope, I mean a hub like this:
Sorry, can't get image to show.
http://subierecycling.com/product/90-99-subaru-legacy-front-right-spindle-knuckle-hub-bearing-wo-abs-28012aa004/#
http://sspparts.com/watermark/1/items/24461/IMG_7613.JPG
Would wouldn't have to drill any hole, things have one about an inch diameter right through where the drive shafts go.
Logged
mbouwer
Hero Member
Country:
Reply #8 on:
January 05, 2018, 10:27:44 AM »
Thanks for the link.
After dismantling and removing a lot of heavy iron you get Reply #2
Then after shaping a light sandwich flange and a locking ring with 6 holes M4 you get Reply #6
Logged
mbouwer
Hero Member
Country:
Reply #9 on:
January 06, 2018, 05:42:35 AM »
Striving for low weight brings many advantages and I think a windmill has a longer lifetime.
The spokes on the hub for the attachment of the magnetrings are shaped out of 1 mm sheet.
Logged
mbouwer
Hero Member
Country:
Reply #10 on:
January 10, 2018, 08:43:42 AM »
Axle+hub.
What I do'nt like is that this way of locking up the front bearing
reduces the through-hole in the axle to 16 mm.
Logged
mbouwer
Hero Member
Country:
Reply #11 on:
January 21, 2018, 05:02:24 AM »
If I remove this locking attachment ring,
and can extend the axis with a threaded socket,
I can use the whole axle inside diameter
for the guiding of the pitch rod.
Logged
mbouwer
Hero Member
Country:
Reply #12 on:
January 22, 2018, 07:32:34 AM »
Extended shaft. Now I can use 25 mm. inner diameter for the guiding system.
Logged
mbouwer
Hero Member
Country:
Reply #13 on:
January 23, 2018, 08:12:05 AM »
After locking up / ajusting the bearing, the nut is secured with two bolts with lock nuts.
Logged
mbouwer
Hero Member
Country:
Reply #14 on:
January 24, 2018, 08:12:42 AM »
The basic stator bracket ring ( where the axis also becomes bolted to )
consists of a ridgid square duct that is composed with 2 mm sheet steel.
Last Edit: January 24, 2018, 08:17:06 AM by mbouwer
Logged
mbouwer
Hero Member
Country:
Reply #15 on:
January 26, 2018, 09:06:25 AM »
Basis to build the other components upon.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Wind
