Author Topic: main shaft and hub study  (Read 4213 times)
mbouwer
« on: January 02, 2018, 08:32:22 AM »
The aim is to search for a main shaft design which I also can easily reproduce for windmill friends.
The axle starting point with two bearings 72-35-17 and 62-30-19 mm.
« Last Edit: January 02, 2018, 09:35:08 AM by mbouwer »
mbouwer
Re: main shaft and hub study
« Reply #1 on: January 03, 2018, 05:09:29 AM »
The assembly with the two standard bearings.
Now I want to try out a different idea based on an axis of a front wheel drive car.
« Last Edit: January 03, 2018, 05:34:42 PM by mbouwer »
mbouwer
« Reply #2 on: January 04, 2018, 05:34:54 AM »
Usefull remaining parts after dismantling a front axle.
« Reply #3 on: January 04, 2018, 02:25:16 PM »
Looks good :)
george65
« Reply #4 on: January 04, 2018, 07:31:38 PM »
I recently picked up some Subaru hubs to build a garden trailer with.
They have a very convenient mounting point where they attached to the struts that can be bolted or welded to a support. Alternately the assembly could be mounted on a ball joint like original so the thing pivots. The ball joints are sealed and last over 100k Km in road use so I'm pretty sure would not be wearing out in a hurry on a turbine.
The disk slides over the studs which retains them regardless of wether the drive shaft is in place or not.
I don't know if using the shaft to mount the alternator back away from the blades would be an advantage or not but it would certainly allow a good degree of weather sealing.
The tail assembly could be mounted on the sturdy arm that the steering rack mounts to.
Guarantee the supply of Subaru spares isn't going to dry up in wrecking yards due to people building turbines.  Threw away about 50 of the things before Christmas because they don't sell a lot  which means they don't fail too often .
mbouwer
« Reply #5 on: January 05, 2018, 05:31:03 AM »
JW,
Thanks for having me on this forum. OP inspires me.
George65,
Do you mean a hub like this?
Important is how big I can drill a bushing hole of a sufficiently large size through the axle.
This is for the guiding of the rod of the pitch adjustment.
mbouwer
« Reply #6 on: January 05, 2018, 05:52:49 AM »
The axle shaped out of the parts I show in Reply #2
george65
« Reply #7 on: January 05, 2018, 08:36:32 AM »
Nope, I mean a hub like this:
Sorry, can't get image to show.
http://subierecycling.com/product/90-99-subaru-legacy-front-right-spindle-knuckle-hub-bearing-wo-abs-28012aa004/#
http://sspparts.com/watermark/1/items/24461/IMG_7613.JPG
Would wouldn't have to drill any hole, things have one about an inch diameter right through where the drive shafts go.
mbouwer
« Reply #8 on: January 05, 2018, 10:27:44 AM »
Thanks for the link.
After dismantling and removing a lot of heavy iron you get Reply #2
Then after shaping a light sandwich flange and a locking ring with 6 holes M4 you get Reply #6
mbouwer
« Reply #9 on: January 06, 2018, 05:42:35 AM »
Striving for low weight brings many advantages and I think a windmill has a longer lifetime.
The spokes on the hub for the attachment of the magnetrings are shaped out of 1 mm sheet.
mbouwer
« Reply #10 on: January 10, 2018, 08:43:42 AM »
Axle+hub.
What I do'nt like is that this way of locking up the front bearing
reduces the through-hole in the axle to 16 mm.
mbouwer
« Reply #11 on: January 21, 2018, 05:02:24 AM »
If I remove this locking attachment ring,
and can extend the axis with a threaded socket,
I can use the whole axle inside diameter
for the guiding of the pitch rod.
mbouwer
« Reply #12 on: January 22, 2018, 07:32:34 AM »
Extended shaft. Now I can use 25 mm. inner diameter for the guiding system.
mbouwer
« Reply #13 on: January 23, 2018, 08:12:05 AM »
After locking up / ajusting the bearing, the nut is secured with two bolts with lock nuts.
mbouwer
« Reply #14 on: January 24, 2018, 08:12:42 AM »
The basic stator bracket ring ( where the axis also becomes bolted to )
consists of a ridgid square duct that is composed with 2 mm sheet steel.
« Last Edit: January 24, 2018, 08:17:06 AM by mbouwer »
mbouwer
« Reply #15 on: January 26, 2018, 09:06:25 AM »
Basis to build the other components upon.
