Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
alternators: does power potential need to be designed to match the intended load
Hmm? I Wonder What They're Building Here
Bearing woes
New reports KD 760 and KD 761 available
3 phase alternator: loads: manifestations of suboptimal magnet coil ratio
Potting Individual Stator Coils
How to connect coils
Wooden Blades
alternators: 3 phase: wire size
48v wind gen project
magnets: to stack or not to stack
Magnet speed
Single stator and rotor 3 phase alternator
coil dimensions for 20mm magnets
Magnets
Magnet Golden Rule
Tell me about the Skystream 3.7
Small Wind Community
comparing a single layer, 10 pole vs 8 pole, 6 coil machine.
Ceramic vs Neo
axial flux alternator. Steel plating question
Un magnetised ferrite rings
Magnet Material
30hp motor conversion....hypothetically
I still exist.
My No2 3.7m dia, (12 footer) gets a rebuild.
I'd like you guys' opinions on these blades
Kris Harbour 2 KW axial flux generator build up !
Wind Gen - Time Flies
Wind Repairs - bearing and blades
Wind Repairs - lightning
Rotor to column connection
How to make sure the column is upright? and in general how to install columns
Sparta Ion front wheel hub motor
report KD 727 about the 4-bladed VIRYA-12 availabel
Digital Wattmeters!
I lost my new blades to a wind storm.
Gravity storage of wind energy
New member with a few questions.
Report KD 748 about a 16-pole PM-generator available
Where to find SITKA SPRUCE and DOUGLAS FIR timber , please ?
New build- 20 foot diameter variable pitch windmill
Fake news !
Report KD 750 about the VIRYA-5R available
Why VAWT technology doesn't advance ?
Venturi effect based wind generation?
MOVED: 2-axis solar tracker (was: axial generator with lamination core)
mechanism to reduce the effect of cogging on startup in low wind conditions
Jim's Cool Things
Disassembly of a small Chinese PM-generator
