Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Misc. 10' Wind Turbine Questions - Part 2
ball bearings as sliprings.is it a good idea??
Update on the extruded PVC blades.
My 10-footer, Presentation coming up
17' turbine - time for maintenance
Otherpower 7 footer air gap
14 inch Rotors
Respooling magnet wire
Coil winding troubles in 20ft project
Coils heat emission
New Wind Turbine Flying
10 ' Axial Flux Homemade
12 footer expected top rpm?
KWH Confusion
Website Tutorial Journal
looking for software
Did my homework
another coil question
more windings give MUCH more power, why?
Fierglass blades, finally out of the mold + Question?
I've been busy these last couple days
Small Axial Flux Performance
Automatic Wind Turbine Shutdown
BMN Wind Turbine Tail Section, neighbors
tubine redesign
need advice on 13 AWG
problem with my coils
fiberglass vacuum layup
Recipe for disaster
winding coils
Induction Motor Conversion
Workshops coming up in Washington State
Chainsaw blades tutorial
20' Diameter Windmill - Grid Connected
When Things go wrong with high winds
Breezy day in south Florida
Guy wire tension
Genset to Base Tower Wire
Sugar pine blades - more metal work
12 volt wiring question: Series or Parallel
Metal Work finally underway
Holes in HUB for studs
Coil winding question
Destroyed windmill
New rotors
Step 1 Rotor Design
Two sets of blades to choose from, grin!
Small, inexpensive first project
Piggott 4 foot
Faraday Cage Lightning protection
