Author Topic: First Induction conversion Done  (Read 3296 times)
coldspot
« on: March 14, 2006, 04:21:34 PM »
I've gotten my first conversion finished
Magnetek
Ser. 38DB 67318P
Mod. CA2D021N" 31-058327-03
  1. V 60Hz
  2. A 800/1550 RPM
.07HP A.O.
Class B INS MAX AMB 40`C
Thats All the Tag Info
I cut down the armature
Glued Neo grade 50 1/2"x1/16"
Two Deep by two wide, (length wise, going inline with arm)
Giving me 8 per pole, using 4 sets of this setup
Stock wires,. 4 coils of #22 & #27, (.025-.027 & .014)
I hooked up the stock three wires to a couple of
Bridge Rec.'s
(salvaged from computer power supply's)
And am waiting to test with a cordless drill
I don't have a half inch chuck one so I must
go to a friends shop to use his.
Cogging is a bit strong but, can still be turned with fingers.
This motor is a bushing not bearing so if it gives good output
I'll be searching for some bearings when I get some cash to play with
Local bearing shop should have something I could adapt to fit.
This motor also has three funky legs pointed towards shaft out end
and I might drill out the rear end and swap arm around to make better
use of these legs as a mounting system later if power is there.
test results posting later today.
« Last Edit: March 14, 2006, 04:21:34 PM by (unknown) »
$0.02
coldspot
Re: First Induction conversion Done
« Reply #1 on: March 15, 2006, 09:10:29 AM »
tested with hand drill
Gen unloaded
  1. RPM = 11.59VDC
  2. RPM = 49VDC
Update on magnets, after running out of first box
I opened an other box an this one has a N35 NOT N50.
« Last Edit: March 15, 2006, 09:10:29 AM by coldspot »
$0.02
coldspot
« Reply #2 on: March 17, 2006, 03:51:06 AM »
Before I go much farther with these little
induction convesions-
Anybody have a plan to help me get up to
charging voltage with less RPM's??
Or should I just plan on unhooking the wires
and reconfiguring to a seperate coils state and
work from there?
I liked the 40+ volts DC but at 1600 RPM, I
dought I'll ever get a blade to spin it.
For testing this little gen conversion,
All I did was lathe down armature and add magnets,
then rectify the stock three wires.
« Last Edit: March 17, 2006, 03:51:06 AM by coldspot »
$0.02
« Reply #3 on: March 17, 2006, 06:48:36 AM »
Not sure if this counts for a 2 speed motor.
Is it 0.07 HP?
The 3 wires. Red, Black & White?
Try only red and white, with black disconnected.
Then only black and white, with red disconnected.
There are 2 sets of coils. Red set and black set.
The white goes to both sets.
Rectifing it as a 3-ph, not sure what would happen, but I would expect some kind of troubles.
If that helps, follow the white wire to its end, cut one of the 2 coil wires, add a blue wire to the one just cut.  Makes 4 wires and 2 single phases. Put a bridge on each pair, parallel the bridge outputs to the battery.
« Last Edit: March 17, 2006, 06:48:36 AM by ghurd »
coldspot
« Reply #4 on: March 17, 2006, 09:35:44 AM »
THANKS ghurd-
I'll look into that
Yes it's a 0.07HP
The rotor will fit into a boxfan one
(was a bit wider but smaller around for easy mag placement)
Also, on a different one-
"AOSmith electric motor"
Mod 324P122
HP 1/4, Rot REV,  Ser 3E88
RPM 1075,   Type FLL
Volts 208-230,   PH 1
Amps  1.5(1.9 Max),   Hz 60
INS    B*  AMB 60`C   Air Over Duty
Code   E46993
Thermally Protected
MFD 5/370V         LR 5072
FS1026S
  Thats ALL tag info
With this
Connection Diagram-
Brown
Brown/w
These to "SEP.CAP."
Yellow
Black
These to "Line"
Also smaller black n white, (two sets each)
to a reverisble plug for rotation
This motor has 6 coils in two seperate sets
inner and outer sets
All are of # 22 wire size, (0.025)
36 slots
This conversion has been done for a few weeks,
(magnets glued to turned down rotor, two deep
two wide and two tall, for a total of eight per pole
4 poles) This fills coil center.
Have a few more mini bridge's out of old computer
power supplies, (most of these tend to be a 600V-800V
4 Amp)
(Did find one 5 leg unit that the AllDataSheet
stated was a 500V, 5 Amp Voltage Doubler, need to figure this one out)
Anyway, any thoughts on this one's wires?
PS: have a Great Day
« Last Edit: March 17, 2006, 09:35:44 AM by coldspot »
$0.02
« Reply #5 on: March 19, 2006, 08:23:44 AM »
Sould be the same???
Best guess...
The yellow and black line wires are the same as black and white?
One of the browns is same as the red?
The other brown is just connected to the yellow inside the motor?
The 0.07 motor should make a dandy (low efficiency) trickle charger with a fan blade, but will take some trial and error before a good blade is found.
Look for a wide slow blade, like a 20" box fan. Expect 12V cut in in a very slow wind.
« Last Edit: March 19, 2006, 08:23:44 AM by ghurd »
coldspot
« Reply #6 on: March 19, 2006, 02:17:03 PM »
Thanks ghurd
someday
I'll finish the boxfan one
I don't like the wire size and have salvaged
some # 18 to use in it.
Also your 4 instead of 6 magnets seems to help the
conversions turn better.
« Last Edit: March 19, 2006, 02:17:03 PM by coldspot »
$0.02
