Author Topic: magnet positioning gig  (Read 2602 times)
brianschanafelt
« on: March 15, 2008, 03:36:06 PM »
Has any noticed that the magnet gig in Hugh's book is scaled down. I thought i had some problems last night when i completed the jig it looked a little small until i measured it and it was 10 instead of 12". Just courious if any body has let him know?
only reason i asked is because in the book it says that you can use the jig that is in the back of the book and line it up with the magnets and punch holes where they will sit. anyway i have got everything worked out. Just seeing if anybody else has ran across this problem
thanks everybody
« Last Edit: March 15, 2008, 03:36:06 PM by (unknown) »
MattB
Re: magnet positioning jig
« Reply #1 on: March 15, 2008, 10:23:52 AM »
Did you get your copy of that book from us (Forcefield)?
The original that Hugh sends to be copied is on European format paper, which is larger than US size. For that exact reason, we make sure the company keeps the size the same, and adjusts the margins...  maybe they got a batch wrong. Or if you got your copy elsewhere... perhaps they copier wasn't aware of that issue...
Are the rectangles on the jig the correct size for the magnets you have?
I'll check our copies when I get a chance to be sure.
-Matt
« Last Edit: March 15, 2008, 10:23:52 AM by MattB »
Re: magnet positioning gig
« Reply #2 on: March 15, 2008, 10:27:42 AM »
I would be reluctant to use any printed information as dimensionally accurate without checking it. I am sure Hugh's original would be life size but you never know what printers do in the various stages of production. In this age it is so easy to change the size of things and a printer would never consider the effects.
At least you have noticed it.
« Last Edit: March 15, 2008, 10:27:42 AM by Flux »
blueyonder
« Reply #3 on: March 15, 2008, 01:27:33 PM »
hi brian your looking at the wrong drawing.
 that one is for the smaller 4 foot you need page 31.
 its not a full scale drawing only a bit.
 so just use it as said in the book.
« Last Edit: March 15, 2008, 01:27:33 PM by blueyonder »
brianschanafelt
« Reply #4 on: March 15, 2008, 06:30:03 PM »
no i got everything worked out, the magnets are about 1/8" bigger than on papier, easy fix just wondering if any body else has noticed.
« Last Edit: March 15, 2008, 06:30:03 PM by brianschanafelt »
luv2weld
« Reply #5 on: March 16, 2008, 09:34:55 AM »
Brian,
I know I'm having a bad day, but your post really left me with a headache.
First, Hugh has written several books. So which one are we referring to???
Second, Did you rip the page out of the book and attempt to use it as a
jig?????
Or did you photocopy it (or scan it into your computer)????
Or maybe you just grabbed a compass and used his pattern as a guide???
As has already been said by others, maybe you used the wrong page????
Kurt, TomW, and others----this should have been locked because
Not Enough Information
I know the answer---this is a diary and anything goes!!!!
Ralph
« Last Edit: March 16, 2008, 09:34:55 AM by luv2weld »
« Reply #6 on: March 16, 2008, 12:46:38 PM »
luv2weld;
*Sigh*
« Last Edit: March 16, 2008, 12:46:38 PM by TomW »
kurt
    • website
« Reply #7 on: March 16, 2008, 06:12:15 PM »
groan what can you do you cannot lock every post on the board nobody ever gives enough info even when you ask for it they ignore you.... drives me nuts....
« Last Edit: March 16, 2008, 06:12:15 PM by kurt »
elvin1949
« Reply #8 on: March 17, 2008, 11:56:00 AM »
  When it gets that bad ,do as i do.
GO-FISHING
Elvin
« Last Edit: March 17, 2008, 11:56:00 AM by elvin1949 »
luv2weld
« Reply #9 on: March 18, 2008, 09:21:49 AM »
Brian,
my apologies for hijacking your thread, but I wanted to answer Elvin.
I wish I could go fishing. We've been snowed in since January.
Got about 5 feet of snow on the ground. Broke the front
differential on my 1 ton pickup trying to plow out of here.
But I said in the first line ---I know I'm having a bad day.
Maybe I should change that to having a bad year!!!!!
You know you're having a bad day when the bird singing outside
your window is a vulture!!!!!!
Ralph
« Last Edit: March 18, 2008, 09:21:49 AM by luv2weld »
elvin1949
« Reply #10 on: March 19, 2008, 03:50:38 PM »
 Supper
 Poached bass.
Elvin
« Last Edit: March 19, 2008, 03:50:38 PM by elvin1949 »
luv2weld
« Reply #11 on: March 19, 2008, 05:31:32 PM »
I may be green with envy now, but come summer time I
wouldn't trade places with you for nothing in the world.
I used to live in Abbeville. Mosquitoes the size of bombers!!!!
And hotter than the hinges of H--l!!! Maybe we should make a trade.
I'll take you elk hunting and you can take me fishing!!!
Ralph
« Last Edit: March 19, 2008, 05:31:32 PM by luv2weld »
elvin1949
« Reply #12 on: March 21, 2008, 02:33:13 PM »
  Interesting thought.
I had to give up big game hunting,neck can't stand the recoil anymore [Only 7 joints in the neck,i have 3 fused and 2 have been trimmed-only 2 to go]
 You are welcome to fish here anytime.
That was a 5 lb-der i had for supper.I got it out of a beaver pond 1/2 mile from the house.7 of those pond's around me.
Elvin
« Last Edit: March 21, 2008, 02:33:13 PM by elvin1949 »
brianschanafelt
« Reply #13 on: March 22, 2008, 07:34:10 PM »
sorry havn't been around went on a little vacation to Zion national park that place rocks. Every time that i go there i see something different.
The book that i have is "High Piggot's How to build a wind turbine". I am building a ten foot design with 24 magnets two rotors 24v. rotors just arrived Monday, They look awesome. I posted this comment to see if it was me doing something wrong or not, Sorry if my posts are vague but i put what my mind is thinking, and as everyone knows it is hard to explain something that somebody else might not understand. Anyway sorry if i am vague, all minds are different.
Thanks again for everybody's input
« Last Edit: March 22, 2008, 07:34:10 PM by brianschanafelt »
