Author Topic: 14-11 stator update.  (Read 1390 times)
« on: November 12, 2008, 05:12:19 AM »
I cast the powdered iron in the 14-11 coil stator form today. It turned out real nice.
I hope to check for cogging tommorow. I think I mixed about a 25% iron amount?
Heres a picture.
I'll report results when there in. I held a ceramic magnet very close. There was just a small atraction.
This is what I wanted. Just enough to enhance the flux path in the air gap a littel.
« Last Edit: November 12, 2008, 05:12:19 AM by (unknown) »
Re: 14-11 stator update.
« Reply #1 on: November 11, 2008, 10:14:38 PM »
PS if this works I'll cut the iron out and enlarge the holes for the coils and then poure the iron in the coil centers.
« Last Edit: November 11, 2008, 10:14:38 PM by Jerry »
capthook
« Reply #2 on: November 11, 2008, 11:44:05 PM »
Looks sweet!
So the cores will be IN the coils, not just under them right?
The small iron mix % could offer a reasonable improvement while adding only barely noticable iron losses.
Thanks for posting this and I look foward to your results!
« Last Edit: November 11, 2008, 11:44:05 PM by capthook »
capthook
« Reply #3 on: November 11, 2008, 11:45:31 PM »
Oh - see your 2nd post you say IN the coils if works - cool.
And what did you use for your iron poweder material?  Brake shavings?
« Last Edit: November 11, 2008, 11:45:31 PM by capthook »
capthook
« Reply #4 on: November 12, 2008, 08:17:41 PM »
"Axial-flux PM Wind Generator with A Soft Magnetic Composite Core"
A paper examining using "the potential application of
soft magnetic composite (SMC) material in low speed, directly
driven, axial-flux permanent magnet (PM) wind generators" (dual-rotor)
http://people.clarkson.edu/~pillayp/axis%20flux%20pm%20wind%20generator%20with%20a%20soft%20magnetic%20composite%20core.pdf
« Last Edit: November 12, 2008, 08:17:41 PM by capthook »
