Author Topic: AXIAL FLUX 2  (Read 5197 times)
xclr82xtc
AXIAL FLUX 2
« on: December 07, 2009, 03:28:48 PM »
i think an illustration will help us all get on the same page...this is the design
im sorry you guys feel im not listening to you..i really am, i just dont get what your trying to say..
ok here is the specs for this
coil length 2 inches
turns 80
1x1 inch coils
4 layers of turns
each magnet is rated at .6403 tesla..i can give you the link if you want
the center large magnet is diametrically alligned so that it will stabalize the horizontal axis of the mill...not nessacary for the PMA but i thought i would show you anyways.
come on guys...i just went and spent 60 dollars on physics books so i can get this...i really want to understand.
NOTE..THE ACTUAL MODEL WILL HAVE 21 COILS...7 Per PHASE...but i feel this representation is the simplest way to get the idea across.  i know that i dont have a number divisible by 3 right now (for 3 phase)..but you get the idea i hope
« Last Edit: December 07, 2009, 03:28:48 PM by (unknown) »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #1 on: December 07, 2009, 03:51:39 PM »
bigger
« Last Edit: December 07, 2009, 03:51:39 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #2 on: December 07, 2009, 03:59:29 PM »
ok last one...the poles were wrong..didnt realize. i reversed them in this drawing
http://www.fieldlines.com/images/scimages/15777/levmag.jpg
« Last Edit: December 07, 2009, 03:59:29 PM by xclr82xtc »
Re: AXIAL FLUX 2
« Reply #3 on: December 07, 2009, 04:23:00 PM »
is it possible to get a Disc magnet that is polarized to the center like that ?
« Last Edit: December 07, 2009, 04:23:00 PM by wooferhound »
Hilltopgrange
Re: AXIAL FLUX 2
« Reply #4 on: December 07, 2009, 04:25:35 PM »
Unless I completely misunderstand your drawing this is a radial flux you are suggesting and not an axial flux as stated! you would be better to double the diameter and put all your mags to the outside with a single stator, with an iron backing ring for the flux return path.  Still wont work as a vawt though! There was a contest on this site a while back to produce a working vawt that actually produced some power, as far as I can remember nobody claimed the prize. That should tell you something in itself.
hilltopgrange
« Last Edit: December 07, 2009, 04:25:35 PM by Hilltopgrange »
How many windmills do I have to build to become a windmillologist?
xclr82xtc
Re: AXIAL FLUX 2
« Reply #5 on: December 07, 2009, 04:27:12 PM »
yes it is..they make them.
« Last Edit: December 07, 2009, 04:27:12 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #6 on: December 07, 2009, 04:29:52 PM »
from my calculations...
34 inch diamter centerline of the coil...it would be .05615 seconds for 1 turn. the large radius of the machine will create enough speed, where as with a wind turbine you have huge blade but the PMA is only a fraction of the circumference of the blades..even though the VAWT turns relativley slowly compared to a HAWT, it produces more torque so you can use larger magnets and not have to worry about cogging.
« Last Edit: December 07, 2009, 04:29:52 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #7 on: December 07, 2009, 04:30:18 PM »
guess i should build this and try to make some power huh? how much was the prize lol?
« Last Edit: December 07, 2009, 04:30:18 PM by xclr82xtc »
frepdx
Re: AXIAL FLUX 2
« Reply #8 on: December 07, 2009, 05:36:02 PM »
Hi xclr82xtc,
I didn't read through the other thread because there were some unpleasant posts, so forgive me if this has already been covered, but just about everything you need for a PMA design is here; http://www.fieldlines.com/story/2004/10/15/22250/879
read down to the posts from Hugh Piggott;
"Turns per phase = 17000 x (System voltage V +1.4) / ( Desired cut in speed RPM) / (Strength of flux in Tesla) / (total area of magnet face in square inches)"
Some rules of thumb - if you have 1/2 inch thick magnets, try to keep the gap between them (where the coil is) not much more than 1/2 inch. Design a completed magnetic circuit; for example, if you have a ring of magnets N,S,N,S try to mount them on a steel ring so their magnetic flux is carried to each other. KISS (you should be familiar with that on ;)
« Last Edit: December 07, 2009, 05:36:02 PM by frepdx »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #9 on: December 07, 2009, 05:48:06 PM »
thank you.
i need to forumlas for a design i already have...i know how many turns, and coils. im trying to figure out the output. it looks to me that formula tells you how many turns you need. for a ceratin voltage.is that right?
« Last Edit: December 07, 2009, 05:48:06 PM by xclr82xtc »
frepdx
Re: AXIAL FLUX 2
« Reply #10 on: December 07, 2009, 05:52:01 PM »
Yes, that's right. And you also need to calculate the coil resistance and make an educated guess about open circuit voltage and voltage under load.
« Last Edit: December 07, 2009, 05:52:01 PM by frepdx »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #11 on: December 07, 2009, 05:57:10 PM »
THATS WHAT I WAS DOING IN THE OTHER THREAD AND EVERY ONE SAID I WAS WRONG!!!
WTF?????????????
sorry not directed at you frep...
i did the calculations using the faraday forumla. and everyone said they were wrong..can you help?
« Last Edit: December 07, 2009, 05:57:10 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #12 on: December 07, 2009, 06:01:37 PM »
coil info
1x1x2
80 turns total, 4 rows of twenty.
center line of coil is 34 inches.
the magnets making 1 revolution per minute would pass the coils at X coils per second...lets figure out X
circumference of a 34 inch circle = 106.8 inches
divide that by 60 seconds...106.8/60= 2.68
so EVERY SECOND...the magnets travel 2.68 inches.  in turn, the magnetic fields pass through the coils at the rate of 2.68inches per second?
am i right to this point?
« Last Edit: December 07, 2009, 06:01:37 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #13 on: December 07, 2009, 06:15:17 PM »
there is 80 coils in 2 inches, so in 2.68 we would have 107turns
the tesla of the magnets is .6403
the area is .75inchx2inch then change to meters squared = 0.003610meters squared
faradays law
N = -1 * (-V/ (( tesla * area meters squared)/ seconds))
107=-1*(-V/((.6403*.003610)2.68)
107=-1*(-V
.002311)
-107=(-V/.002311)
.2472=V
so right now we have 107 turns = .2472 v at at rate of 1 rpm....
now there is 7 coils of 80 so thats 560 total turns
divide by 107 =5.233
so times 5.233  time the Voltage .2472
=1.29 volts per phase...
my math looks more right this time lol but is it?
« Last Edit: December 07, 2009, 06:15:17 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #14 on: December 07, 2009, 06:26:32 PM »
now how many feet of wire in a coil (we need to find the resistance)
wire info
Nominal Diameter: 0.10 inch
Nominal OHMS/LB. -20 Celsius: 0.0314
Feet/LB: 31.48
outersize of coil is 1 inch. 4 layers and the core is .6inches.(yes this does take into account wire size) .so the  perimter for one layer of turns  is (.7*4)+(.8*4)+(.9*4)+.(1*4)2.8+3.2+3.6+4=13.6inches
now the coil is 2 inches long so we need have 20 layers...20*13.6=272inches...divde by 12=22.6 feet or wire per coil...nice. lol
ok so now we know we have 7 coils so 22.6*7 = 158.2 feet.
its 31.48 feet per lb  so 158.2/31.48=5.025lbs
5.025 * .0314
.1578
so the TOTAL resistance of all seven coils is .1578ohms
« Last Edit: December 07, 2009, 06:26:32 PM by xclr82xtc »
Perry1
Re: AXIAL FLUX 2
« Reply #15 on: December 07, 2009, 06:27:09 PM »
What does 106.8/60 equal again?
« Last Edit: December 07, 2009, 06:27:09 PM by Perry1 »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #16 on: December 07, 2009, 06:34:22 PM »
1.78..
did i mess up? lol
let me check it again...i got more path i need to post
« Last Edit: December 07, 2009, 06:34:22 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #17 on: December 07, 2009, 06:35:18 PM »
damn i fat finger it...lol..that messed it all up
ill go back and redo it. just dont post anything, ill post all the math when im done.
« Last Edit: December 07, 2009, 06:35:18 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #18 on: December 07, 2009, 06:45:30 PM »
ok here is all the math...i think its right..feel free to check it, i am at the point where i need to  convert my single phase numbers to 3 phase, and acccount for having 15 pairs of magnets...not just 1, which is what these calcs show.
i think with three phase you leave the voltage the same and times the amperage by 70.7% is that right? i saw that somewhere last night, but i dont know if its right.[b]
coil info
1x1x2
divide that by 60 seconds...106.8/60= 1.78
so EVERY SECOND...the magnets travel 1.78 inches.  in turn, the magnetic fields pass through the coils at the rate of 1.78 inches per second?
____________
there is 80 coils in 2 inches, so in 1.78seconds we would have
faradays law
N = -1 * (-V
71.2=-1*(-V/((.6403*.003610)1.78)
71.2=-1*(-V
-71.2=(-V/.00129)
.0918=V
so right now we have 71.2 turns = ..0918 v at at rate of 1 rpm....
divide by 71.2 7.87
so times 7.87  time the Voltage .0918
=.722 volts per phase...
wire info
Feet/LB: 31.48
outersize of coil is 1 inch. 4 layers and the core is .6inches.(yes this does take into account wire size) .so the  perimter for one layer of turns  is (.7*4)+(.8*4)+(.9*4)+.(1*4)=2.8+3.2+3.6+4=13.6inches
5.025 * .0314
.1578
_
_________________
so now we know the total voltage of one phase at 1 rpm of the mill, and we know the constant resistance of the coil. (i also have the inductance of each coil but i dont think we need it.)
so with this info, we SHOULD be able to figure out the amps using ohms law. i=v/r
.722/.1578=4.578AMPS
SOOOO......per phase, at 1 rpm we have 1.29 volts and 4.578 amps. kinda crappy, but hey its only turning at 1 rpm, and thats only using 1 pair of magnets, there is 15 total pairs.
« Last Edit: December 07, 2009, 06:45:30 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #19 on: December 07, 2009, 06:48:29 PM »
this line should read
there is 80 coils in 2 inches, so in 1.78inchs we would have  71.2coils
« Last Edit: December 07, 2009, 06:48:29 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #20 on: December 07, 2009, 06:55:51 PM »
using this caLC
http://www.csgnetwork.com/ohmslaw2.html
I  get 3.303 watts per phase.times that by 3 phases and i get 9.909watts
enter the volts and watts into the 3 phase calc and i get roughly 8 amps...
However i have no clue if this is right.
times that by 15 magnet pairs and wouldnt you get 40 amps at the speed of 1rpm?
it might stall but is my math at least right?
« Last Edit: December 07, 2009, 06:55:51 PM by xclr82xtc »
Perry1
Re: AXIAL FLUX 2
« Reply #21 on: December 07, 2009, 07:07:41 PM »
Are your magnets or rectangular? Can you be more specific on their size and shape?
What do your coils look like? Short fat cylinders or long thin. Can you eloborate on their size and exact shape?
Perry
« Last Edit: December 07, 2009, 07:07:41 PM by Perry1 »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #22 on: December 07, 2009, 07:12:50 PM »
the picture at the top of this page show the setup..so you can get what im talking about..
the magnets are cylinder .75inch diameter 2 inches long....here ...its these big boys
http://www.kjmagnetics.com/proddetail.asp?prod=DCY0
i used the full gauss amount for the calculations since im actually using two magnets. realistically, the number should probably be closer to .8 tesla
the Coils are basically 2inch cubes stretched out to a 2 inch rectangle.
i was right on at 80 turns using a .6 inch air core, it just happed to work out to be 2 inches.. that was just a good guess though lol.
the coils are wrapped in 20 turn layers, 4 layers for a total of 80 turns
« Last Edit: December 07, 2009, 07:12:50 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #23 on: December 07, 2009, 07:15:55 PM »
sorry i describe the coils wrong...they are basicall TWO 1 inchcubes sat side by said to form a 1x1x2 rectangle. sorry my other description was misleading
« Last Edit: December 07, 2009, 07:15:55 PM by xclr82xtc »
Hilltopgrange
Re: AXIAL FLUX 2
« Reply #24 on: December 07, 2009, 07:28:48 PM »
  1. Axial flux alts as built here do NOT cog, they cant cog if they don't have iron in the stator
  2. 15 magnet poles wont work as the poles must alternate ie NSNSNS YOU Must use an even number of poles otherwise you end up with two like poles beside each other ie NSNSN
  3. The ratio of coils to mags should be 4 poles to 3 coils
  4. when you know the output voltage of a single coil you multiply that figure by the number of coils per phase and then you multiply that by 1.73 for 3 phase.
You should spend some time reading past stories on this site as it has all been covered many times and will save you a lot of time making very basic mistakes.
A more simple approach is to build your magnet rotors and then insert a test coil same as I did on my last build here
Part one http://www.fieldlines.com/story/2009/5/23/135436/243
Part two http://www.fieldlines.com/story/2009/6/21/22551/6284
Part three http://www.fieldlines.com/story/2009/7/20/11923/2353
going to bed its 3.30 am here
hilltopgrange
« Last Edit: December 07, 2009, 07:28:48 PM by Hilltopgrange »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #25 on: December 07, 2009, 07:37:44 PM »
thanks alot hilltop, those threads looklike they will help alot.
when you have some time, i hope maybe you can read more into my calcualtions and help my with the 3 phase conversions.
« Last Edit: December 07, 2009, 07:37:44 PM by xclr82xtc »
Perry1
Re: AXIAL FLUX 2
« Reply #26 on: December 07, 2009, 07:56:37 PM »
A couple places where you are veering off course.
1.) Your magnets are rods, why are you calculating their area like they are a rectangle? Us pi*r^2 for the area.
2.) for your time in the denom (seconds) you use 1.72 inches per second. Is that a unit of time? 'speed' in the formula refers to how many seconds it takes to perform a revolution. you should be using 60 sec here. Always put units in your calc's, if they don't cancel out in the end you have a wrong answer. It's usually a bad sign when your equation has both english and metric units in it.
3.) The Gauss you are quoting for this magnet is surface Gauss. Near the center of your air gap it would be approx 50%
Perry
« Last Edit: December 07, 2009, 07:56:37 PM by Perry1 »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #27 on: December 07, 2009, 08:04:24 PM »
1 i used a cylinder surface area calulator. i will do it by hand
2 i was told that the N should equal the seconds when you didnt know the voltage. likewise if you knew the voltage and didnt know the N then you would of course use 60 seconds. but i will redo it, and see what happens. i still have not competly grasped faradays law but i will try
3 agree that it will drop by half. but using 2 magents would bring it back up wouldnt it?
« Last Edit: December 07, 2009, 08:04:24 PM by xclr82xtc »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #28 on: December 07, 2009, 08:14:40 PM »
Surface Area = 2(pi r 2) + (2 pi r)* h
that answer was correct for surface area
71.2=-1*(-v/((6304*0.003610)60)
71.2 -1*(-v
((.002276/60)
71.2 =-1*(-v/((3.75*10^-5)
-72.1
(v/.0000375)
.00541=v
look right?
« Last Edit: December 07, 2009, 08:14:40 PM by xclr82xtc »
Perry1
Re: AXIAL FLUX 2
« Reply #29 on: December 07, 2009, 09:34:32 PM »
Area is = pi * r^2
You only want the surface area that the flux passes through perpendicularly.
« Last Edit: December 07, 2009, 09:34:32 PM by Perry1 »
xclr82xtc
Re: AXIAL FLUX 2
« Reply #30 on: December 07, 2009, 09:48:54 PM »
ah...ok, that website told me entire area, if thats the case, i need to get magnets with a larger radius
« Last Edit: December 07, 2009, 09:48:54 PM by xclr82xtc »
