Author Topic: VAWT backyard experiements  (Read 121452 times)
brandnewb
Re: VAWT backyard experiements
« Reply #132 on: February 10, 2024, 07:59:19 AM »
Hey Bruce, I hear you like making things yes?
Let us get together and make this speed govenor ;)
15835-0
Hahahah!! This is one of those times AI went totally over board ;)
brandnewb
« Reply #133 on: February 10, 2024, 08:41:43 AM »
ok so early test results suggest that a back iron plating does not benefit a repelling configuration.
So that means that unless I find counter evidence the coming days then traditional still reigns supreme in this dual rotor setup.
brandnewb
« Reply #134 on: February 10, 2024, 08:58:51 AM »
but this makes me question the whole concept of back iron plating.
I mean let us take a mental image.
The idea of back plating is to reduce the resistance for the field to travel trough right? But to where? Yes of course abviously the other pole but in a dual rotor setup where is that pole?
Indeed not on the same disk. So would not then back plating only hurt the intended gain?
hmmm I must be overlooking something glaringly obvious yet for me not yet visible.
brandnewb
« Reply #135 on: February 10, 2024, 09:06:43 AM »
hahah this makes me realize that sometimes one does not need to understand something fully in order to use the effects of it ;)
I mean I am still breathing yet know sooooo little on how it actually works. ;)
brandnewb
« Reply #136 on: February 10, 2024, 09:40:57 AM »
it takes around 1.05 KG to stop the blades rotating while the wind speed is at around 1.5m/s
Do I have reason to celebrate or indeed go lift type ;(
I really am not looking forward to going lift at this stage in time.
brandnewb
« Reply #137 on: February 10, 2024, 09:47:33 AM »
no, lift only comes into play when the self destruct mechanism has been proven to be reliable and also that the whole structure can float on water.
Only then we will see how far lift can increase things.
« Reply #138 on: February 10, 2024, 12:59:56 PM »
Quote from: brandnubell
The device I was referring to is called a "governor." In elevator systems,
When it comes to Wristwatch, my grandfather was a repair outfit.
I was talking to him about the "regulator" he said NO its the escapement...
« Reply #139 on: February 10, 2024, 01:49:04 PM »
Quote from: supernewbe
I will update this thread/edit. Im cooking some food to  :)
brandnewb
« Reply #140 on: February 10, 2024, 10:14:47 PM »
hahahahhahh
brandnubell
I love how you take effort to change my avatar name.
hahahha
it is a novel twist. One I have not ever seen before in all my years.
hahahha
brandnewb
« Reply #141 on: February 11, 2024, 08:27:04 AM »
Anyway JW, Let me just state that sharing food is a good way to bury hatchets.
So please accept my invitation that should you ever come over to the wrong side of the pond and be near by. Then please be my guest. I will make sure the dining table is full of abundance.
ohh my now I have to start practicing else risk yet other way of reputational damage if my food is not of quality ;)
I really mean this all light heartily and with intend to just be cool and frivolous.
Perhaps if you would extend me the courtesy of editing my own logbook/dairy? It would feel less of an invasion of personal space that way. I am sure that you intended it that way this section yes?
« Reply #142 on: February 11, 2024, 08:10:39 PM »
No, your fine.
I was hopping that you had made recipes and cook etc. Check out my link.
https://www.fieldlines.com/index.php/topic,144905.msg986159.html#msg986159
brandnewb
« Reply #143 on: February 12, 2024, 07:04:05 AM »
Ok I have given up on trying to correlate wind speed to an RPM and thus frequency of field reversals at low wind speeds (<3m/s).
Safe to say there is no consistency to be found and that is probably all because of turbulence and general wind direction that is changing a lot and within the footprint of the turbine I can imagine it being in a constant .. well turbulence. I am repeating my self ;).
The amount of work I have to put into analyzing a correlation is too off putting. It is not helping me to just get going.
So I am hoping for the wind to pick up again soon so I can take a few more looks at around 5m/s to see what kind of RPM the turbine rotates then.
But I would not be surprised that also then readings will be all over the place.
So I guess then I should be focusing on what is the max RPM allowed. and make sure that the PMA does something worthwhile well below that.
I also do not know a better idea at the moment :(
brandnewb
« Reply #144 on: February 12, 2024, 08:35:12 AM »
yeah no, this is proving rather impossible.
I am already at 8 seconds per revolution while the weather station registers 3.4m/s.
Now it is all about wind direction I think.
needless to say this will be difficult to really lay a finger on.
brandnewb
« Reply #145 on: February 12, 2024, 09:29:36 AM »
more than 7KG breaking force required to stop the blades spinning at around 3.4m/s
It would be great if the Adriaan would come back and either confirm or deny that these readings are something to write home about.
brandnewb
« Reply #146 on: February 12, 2024, 09:34:14 AM »
ohh wow!! I just realized why going floating might be the dumbest idea ever.
All this effort I put into keeping things safe and working towards having this bird float on water. The very water my family , neighbors and my self swim in each summer. With potentially lethal currents going mayhem.
Bad IDEA
brandnewb
« Reply #147 on: February 12, 2024, 10:09:56 AM »
Please witness the bird at glide mode on the new column. Stealth if you will even. But then only for the auditory sensors.
brandnewb
« Reply #148 on: February 12, 2024, 10:13:11 AM »
I am aware of a million things to improve upon.
And I can imagine there are like a ten fold of that on things I am not yet aware of I need to improve on.
It is just so peaceful and mesmerizing watching the phoenix spin. How ever slowly. Yet slow is what we want!! slowwww is better in this context.
« Last Edit: February 12, 2024, 10:30:04 AM by brandnewb »
brandnewb
« Reply #149 on: February 12, 2024, 10:22:22 AM »
BTW, that is not to say that I think I do not need advice.
I think we have already established that I can use advice more than anyone else!!
So if you see something on the turbine that warrants attention then please let me know.
I will always love you for it even if I already saw that particular issue.
It is my 70% 30% 100% rule.
Even though I might already know 70% of the advice given. it are the 30% we are looking for. And the thanks extended to any advice should always be a 100%.
« Reply #150 on: February 12, 2024, 04:25:32 PM »
Reply
Here my obvious looking/.
For Me its ben posting videos
The system, login
« Reply #151 on: February 13, 2024, 11:01:54 PM »
The way your top and bottom allow leakage out of the blade is a must.  Its okay to have holes in your blades, preferably to only induce enough drag to get the result you want.  Human nature leads us to create cups, but if the air cannot leak then stagnant air gathers at the blade.  The leakage allows stagnated air to clear the blade.  The barrel-conversion savonius designs often prevent this leakage and it kills efficiency.  The air should flow around the blade rather than be stopped/blocked by it.  You want that clean air to be accessible to the blade.
brandnewb
« Reply #152 on: February 14, 2024, 12:02:41 PM »
Yes brother, please keep it coming!!.
Yet before I had a chance to even start on poking holes in the blades the Pheonix had other plans.
She started to generate a sound that resembles a middle C of a piano. Something around 256Hz. {1}or 440 Hz wha Ii actually believe to be more accurate{/1}
Needless to say now my focus is on what it is she is trying to tell me.
I already have a strong indication that it is this bearing I use to keep the bird upright.
Now if ever I have had a good reason to go scify then now is it.
I mean if store bought bearings start failing  then why not try something more futuristic?
« Last Edit: February 14, 2024, 12:28:16 PM by brandnewb »
brandnewb
« Reply #153 on: February 14, 2024, 01:40:52 PM »
so I have managed to keep my neighbours from revolting against me by overdosing both bearings with WD40.
Now although only the top bearing decided to want to become an opera singer I think this is just a waiting game.
See how long something lasts.
hmm ok well my current track record of components used is the embodiment of how NOT to do it if durability is in mind.
MagnetJuice
« Reply #154 on: February 14, 2024, 05:34:25 PM »
Trailer hubs are cheap and should be strong enough for that structure.
15851-0
« Reply #155 on: February 15, 2024, 06:55:46 AM »
The most important neighbor in my case is the wife. :D
The nastiest noise I've ever had was when the top of a tube was being rubbed.  Kind of like the sound a glass makes when you wet your finger and do circles across the top.  Only about 1,000x louder.
« Reply #157 on: February 16, 2024, 11:16:00 AM »
You should here the tower next to the house when the grease runs dry in the tube the mast turns in... steel on aluminum... that tower is attached to the house so the noises go right into the house structure!
« Reply #158 on: February 18, 2024, 05:33:21 PM »
This guy went with an exterior scoop, and its a pretty similar radius IMO.
https://www.youtube.com/watch?v=h-FqF21wyLc
Notice his pulley size.
« Reply #159 on: February 18, 2024, 09:58:28 PM »
That is a lift/drag type wing, a different design philosophy...
« Reply #160 on: February 19, 2024, 07:00:27 AM »
Its a modified Lenz, so its a different scoop design.  The point of the link is to show how massive the pulley ratio he went with.  I personally would have gone two smaller stages using chains, but that is just my preference.  It was going to be loud regardless of the choice.
brandnewb
« Reply #161 on: February 22, 2024, 09:49:23 AM »
brace for impact!!!
are going to be my infamous last words if storm Louis, that will be here tonight, has anything to say about that.
Now I am going to do something stupid. I am leaving the Phoenix errect. I did fortify the guywires though.
I just need to see what will happen so I can learn what to focus on next iteration.
brandnewb
« Reply #162 on: February 22, 2024, 10:34:15 AM »
ohh wow,
Now I am getting nervous!
I tried keeping the Phoenix on a diet. So far that has been working out rather nice.
But what If the guy wires decide to go on a strike?
Then the whole bird will actually fly!!
hmmm.
hmm.
I will reconsider going full steel or maybe even lead ;) who cares about the health impact of lead anyways ;)
brandnewb
« Reply #163 on: February 22, 2024, 11:53:19 AM »
nooooooo. even before the storm hit, yeah sure things are picking up already here, I already have to take her down.
It is the part that prevents the upper bearing from slipping down that is in serious need of redesign.
nooo. Now I have missed this window op opportunity to see thing horribly go wrong :(
brandnewb
« Reply #164 on: February 22, 2024, 03:12:14 PM »
I am actually thankful JW. Now I have again in my playlist this song!!
And in some ways I think what you tried to tell me is that I am needed.
Thank you JW!
Reply
The system, login
