Author Topic: PVC Pipe prop plans and History  (Read 10517 times)
« on: April 19, 2005, 04:14:31 PM »
 I have been moving my better projects into my diary. But while I did draw up the plans for the PVC Pipe Props, Zubbly was
the one that pretty much invented them. This is why they are called ZubWoofer Props. So instead of reposting the Prop plans
in my diary, I decided to post the history and evolution of these props. Some fo the pictures in the earlier posts don't
show up because Zubbly was also learning how to post pictures at this time too.
Zubbly invents the PVC props and first mentions that he is making Props from Pipe
http://www.fieldlines.com/story/2003/9/7/16254/83196
Some of Zubbly's first descriptions of the Props he is making
http://www.fieldlines.com/story/2003/10/5/185824/882
The first good pictures of the PVC Props and discussion of durability
http://www.fieldlines.com/story/2003/10/19/171250/17
Plans are starting to emerge and Wooferhound is posting Drawings Too
http://www.fieldlines.com/story/2003/10/25/020/94523
Wooferhound starts making Props and makes a 4 Blade version
http://www.fieldlines.com/story/2003/10/29/17144/245
After talking on IRC chat Wooferhound decides to Draw Plans for the props
http://www.fieldlines.com/story/2003/11/11/172721/53
Wooferhound makes PVC Savinous experiment
http://www.fieldlines.com/story/2003/12/1/122243/608
And that is why they are called ZubWoofers
It's really cool for me because I am seeing pictures of them from all over the world
Recently 'stevesteve' a user in the UK wrote a computer program that greatly simplifys the measurements needed to cut one of
these blades out of the pipe. You can download the program from this story
http://www.fieldlines.com/story/2005/4/17/6437/83378
Happy first time cheap prop building from Wooferhound
« Last Edit: April 19, 2005, 04:14:31 PM by (unknown) »
Re: PVC Pipe prop plans and History
« Reply #1 on: April 19, 2005, 07:54:45 PM »
thanks nice and dense information
« Last Edit: April 19, 2005, 07:54:45 PM by electrondady1 »
gizmo
    • The Back Shed
« Reply #2 on: April 20, 2005, 12:40:46 AM »
I've been using PVC for my smaller windmills, but on a 3 blade propeller.
How will that calculator program work with 3 blades? I used Warlocks calculator to get the angles and it seams to work ok, but "stevesteve"'s would be a lot easier to use.
Glenn
www.thebackshed.com
« Last Edit: April 20, 2005, 12:40:46 AM by gizmo »
stevesteve
« Reply #3 on: April 20, 2005, 01:56:39 PM »
Glenn,
Should be OK for you. The calculator just works out the width of the paper template for required angles for a particular pipe diameter (angles and diameter set to your requirements).
I'm intending to do something similar myself. I am trying to locate some larger diameter pipe in the UK. I can only get 4" so far.
Cheers, Steve
« Last Edit: April 20, 2005, 01:56:39 PM by stevesteve »
MtnTopRebel
« Reply #4 on: April 20, 2005, 02:44:48 PM »
Humm might be a solution for me... I have an old gear drive Pre REA windmill, that needs blads.  The unit is designed for two blades but I might have to modify it to 4 and shorter blades....  guess I will need to dig it out get a pix and seek some advice...
« Last Edit: April 20, 2005, 02:44:48 PM by MtnTopRebel »
nanotech
« Reply #5 on: April 20, 2005, 05:26:50 PM »
Find a construction company.  They should have up to 10 inch diameter pipes for commercial sewer lines.
Might have to sand the blades thinner, because at a 10 inch diameter, the pipe's going to be kinda thick.
Don't know whether shipping would kill you, but these guys have quite the selection.....
http://www.pipeplus.com
« Last Edit: April 20, 2005, 05:26:50 PM by nanotech »
Peppyy
« Reply #6 on: April 20, 2005, 08:43:18 PM »
Hey, don't forget about these that charge my booster packs.
« Last Edit: April 20, 2005, 08:43:18 PM by Peppyy »
« Reply #7 on: April 21, 2005, 06:39:32 AM »
    Do you have details on this one?
  Diameter of pipe used ....diameter of swept area...rpm in 6-8mph wind?
    Looks good!
              ( :>) Norm.
« Last Edit: April 21, 2005, 06:39:32 AM by Norm »
stevesteve
« Reply #8 on: April 22, 2005, 06:29:16 AM »
They seem to be US based but I will check out some UK construction suppliers.
On the other hand a 3' or 4' section would do so I might cruise the local building sites touting for offcuts!
Cheers, Steve
« Last Edit: April 22, 2005, 06:29:16 AM by stevesteve »
windyknight
« Reply #9 on: April 23, 2005, 10:07:39 AM »
Whats merit in 4 blades vs 3 - cant seem to find info on pros and cons!
« Last Edit: April 23, 2005, 10:07:39 AM by windyknight »
Peppyy
« Reply #10 on: April 23, 2005, 04:44:51 PM »
I have some information on them here
http://www.fieldlines.com/story/2005/1/6/232942/4004
They were made from 4" pipe and are 48" long.
Windyknight, the only reason I made this a 4 blade setup was for use of material VS. strength. It was a whole lot easier than building a fancy hub and bolting everything together.
I have no scientific data to support it but from what I have read here in the last couple months I would be willing to bet I would get better performance from 3 blades. It has to do with what I call "Prop wash". At higrer rpm's the air is still disturbed when one follows the other at 90 degrees apart. With 3 you have 120 degrees between them allowing a bit more time for the air to settle back into it's path, thereby creating more power.
Of course, the swept area would be smaller, limiting the power factor and the startup speed so the low rpm performance would be slightly less. I guess it is a bit of a tradeoff and without some real test figures it is all theory.
« Last Edit: April 23, 2005, 04:44:51 PM by Peppyy »
windyknight
« Reply #11 on: April 24, 2005, 02:39:02 AM »
Think there might be some torque benefits, I seem to recall most planes with 4 blade props were carriers rather than fighters but someone must have data! k
« Last Edit: April 24, 2005, 02:39:02 AM by windyknight »
jimjjnn
« Reply #12 on: April 24, 2005, 08:39:40 AM »
WWII  F4U(?) Corsair had 4 blades and 13 foot swept area. That was the reason for the  gull wing shape of it's wings.
« Last Edit: April 24, 2005, 08:39:40 AM by jimjjnn »
« Reply #13 on: April 24, 2005, 01:53:35 PM »
   A four-bladed prop on a plane was supposed
to be quieter than a 2 or 3 bladed one.
             ( :>) Norm.
« Last Edit: April 24, 2005, 01:53:35 PM by Norm »
rotornuts
« Reply #14 on: April 24, 2005, 04:56:21 PM »
"silent running" hellicopters such as the MD 500E utilized 5 blades instead of the standard 4 so they could reduce the rotors rpm and still generate the same lift. The reduced tip speeds yielded a noticably quieter rotor according to the manufacturer. "NOTAR" also dramaticly improved the noise levels.
« Last Edit: April 24, 2005, 04:56:21 PM by rotornuts »
di34
« Reply #15 on: February 20, 2008, 08:28:33 AM »
Hi Great information
Here is useful info Alise
« Last Edit: February 20, 2008, 08:28:33 AM by di34 »
