Author Topic: I found a real nice Rotor and Spindle assembly  (Read 1567 times)
« on: January 08, 2006, 02:45:59 PM »
Mountain Man should recognize it.
it's from a Caddy
part# 7470595
year 1990-1993 Cadillac Deville & Fleetwood
Looks sweet doesnt it??
« Last Edit: January 08, 2006, 02:45:59 PM by (unknown) »
para t8
Re: I found a real nice Rotor and Spindle assembly
« Reply #1 on: January 08, 2006, 08:24:27 AM »
im going to the junkyard find me one of them puppys,that nice,i think that would work fine.it looks new did you order it from autoparts or found it?  para t8
« Last Edit: January 08, 2006, 08:24:27 AM by para t8 »
« Reply #2 on: January 08, 2006, 09:02:18 AM »
i found the pics and the info online , But they are sold out :(
I too will be visiting a local junkyard ;)
« Last Edit: January 08, 2006, 09:02:18 AM by willib »
« Reply #3 on: January 09, 2006, 04:04:46 PM »
I got one today !! i just called the Junk Yard ,and asked for a wheel hub for the 1990-1993 Cadillac Deville or  Fleetwood, they had four!
The one i ended up with was actually from a bonneville !
man it spins sweetly
« Last Edit: January 09, 2006, 04:04:46 PM by willib »
« Reply #4 on: January 09, 2006, 09:47:41 PM »
this is it cleaned up.
The Bolt circle dia. is ~ 4.527" , and the whole plate is 5.910 dia.
I quess GM has been making these for some time as this one is from a  '88 Bonneville ..
I think i'll keep that brake drum backing plate  .
Its 11" in dia,and should make a nice stator holder.
this is it before cleaning..
, and the mountings seem perfect for a  furling pivot point..
this is it with the brake pads and the wheel cylinder on there .
I saw on the net where somone made a load cell out of a wheel cylinder and a pressure gage.
« Last Edit: January 09, 2006, 09:47:41 PM by willib »
mlz
« Reply #5 on: January 10, 2006, 07:42:38 AM »
Ok, now I feel stupid, I have an 88 and an 89 Bonnie in my back yard, Neither has it's engine, and one is missing the entire front end.  I think before I have the wrecking yard haul them off (they are required to here) I'll snag those bearings along with the other misc. junk I want off of them...  Thanks for the tip!
« Last Edit: January 10, 2006, 07:42:38 AM by mlz »
Ding123
« Reply #6 on: January 24, 2006, 08:04:23 PM »
I am glad I stumbled on to this post, I ordered my magnets today from Wondermagnet.
I will have to wait a week or so because I live in Canada for delivery but, I was just about to buy a trailor hub before I saw this post.I have an 1989 Oldsmobile junker and after reading this post I went out to have a look at the rear and there was the hub.Thanks for the tip.
« Last Edit: January 24, 2006, 08:04:23 PM by Ding123 »
« Reply #7 on: January 30, 2006, 12:05:14 PM »
ding check out my other post the one on making a lathe..
you may be able to use the front wheel hub instead..
« Last Edit: January 30, 2006, 12:05:14 PM by willib »
