Author Topic: Pitch control diagram  (Read 6247 times)
« on: January 11, 2006, 07:08:40 PM »
I'm really stuck on this idea , cant get it out of my head.
http://www.otherpower.com/images/scimages/2965/pitch_control.GIF
the servo could be PIC controlled and powered by a small set of spinning coils rotating against a fixed set of magnets .
i got the idea for the connections to the blades ,from the picture below .but i've added a third blade. thoughts?
Flux i would really like to see a photo of your pitch control mechinism.
« Last Edit: January 11, 2006, 07:08:40 PM by (unknown) »
Re: Pitch control diagram
« Reply #1 on: January 11, 2006, 12:46:24 PM »
  A company called Ivo Prop makes an inflight adjustable prop using a small DC motor.   I've set up a couple of them on some small aircraft.  There is a steel shaft down the center of the composit blades which gets twisted.   It's a clever, simple system.   I've often thought of moving the design to wind turbines.   You can see the set up on http://www.ivoprop.com/inflightultralightmodel.htm .   I have one on a 2 seat plane and some damaged blades in the shop.   Damaged from a loose exhaust nut flying through it on take off.
« Last Edit: January 11, 2006, 12:46:24 PM by windstuffnow »
« Reply #2 on: January 11, 2006, 01:01:24 PM »
I didn't take any photos of mine, but I did save an early drawing that will give you some idea but it will be difficult to follow the mechanism to synchronise the blades without knowing something of the Elektro hub that I based it on.
Should be details on the net of Jacobs, Dunlite, Aerowatt and similar ideas, many tried it.
Not sure how it will come out on the screen but if you look in my files you can find it as a gif or jpg and if you load them and look at it bigger it should be ok.
« Last Edit: January 11, 2006, 01:01:24 PM by Flux »
« Reply #3 on: January 11, 2006, 01:34:35 PM »
This link should show a pitch control hub by JacquesM and there ought to be other pictures somewhere.
http://www.fieldlines.com/story/2004/11/11/8830/1379
« Last Edit: January 11, 2006, 01:34:35 PM by Flux »
« Reply #4 on: January 11, 2006, 05:34:23 PM »
Ed , i dont see how they change the pitch of the blades , on these ?
http://www.ivoprop.com/images/electricpropsystem.JPG
« Last Edit: January 11, 2006, 05:34:23 PM by willib »
« Reply #5 on: January 11, 2006, 05:36:39 PM »
I see how that works, although they use three actuators..  when all you really need is one..
« Last Edit: January 11, 2006, 05:36:39 PM by willib »
« Reply #6 on: January 11, 2006, 05:40:16 PM »
I didnt find a pic of his pitch control ,close up , but his photo uploads are gone :(
« Last Edit: January 11, 2006, 05:40:16 PM by willib »
« Reply #7 on: January 11, 2006, 07:51:47 PM »
  The motor drives a screw drive, the gold part is a thimble that the steel inserts are connected.   What it does is pull the steel up or down to flex the blades.  The pitch change is quite dramatic, at full pitch it will bogg a 65hp engine.   I ended up having to put in end stops to keep the blade from going to far from one extreem to another.  It does a nice job going from extreem thrust for take off down to a nice load for fuel economy.   I only used that as an example to setting something up on a pivot instead of building a set of flexible blades.  It's really a simple system.
« Last Edit: January 11, 2006, 07:51:47 PM by windstuffnow »
« Reply #8 on: January 11, 2006, 08:12:36 PM »
How do the blades pivot ?
How does pulling on the blades change the pitch?
is there a wire in the blades? are they hollow?
sorry for so many questions.
« Last Edit: January 11, 2006, 08:12:36 PM by willib »
« Reply #9 on: January 12, 2006, 11:47:29 AM »
  It has a steel rod through the center of the blade, cast into the composit.  Both ends of the steel insert has a 90 deg bend, the motor uses the lever to pull or push on one end of the steel arm which inturn twists the outer 90 flexing the blade to change pitch.
« Last Edit: January 12, 2006, 11:47:29 AM by windstuffnow »
dalibor
« Reply #10 on: January 12, 2006, 11:51:29 AM »
the french company "eoltec" is using similar control on their 2-blade system . something with opposite weight on axe of blade plus some kind of springer . nice pics can be seen on their site about it. www.eoltec.com
check out PDF broschures there
« Last Edit: January 12, 2006, 11:51:29 AM by dalibor »
« Reply #11 on: January 12, 2006, 01:38:24 PM »
willib, if you are referring to my drawing, the things that you think are actuators are just weights. They look like pistons on the drawing but the thing is weight operated, there is no active servo.
« Last Edit: January 12, 2006, 01:38:24 PM by Flux »
« Reply #12 on: January 12, 2006, 03:33:58 PM »
Yeah i see that now , thanks
« Last Edit: January 12, 2006, 03:33:58 PM by willib »
« Reply #13 on: January 12, 2006, 03:46:06 PM »
I looked at their site ,6 KW from 18+ foot blades is pretty good , they are able to hold the gen. at a constant speed by using mppt and Passive weight pitch control .
http://www.eoltec.com/Documents/Scirocco%20V02c_Eng.pdf
« Last Edit: January 12, 2006, 03:46:06 PM by willib »
elvin1949
« Reply #14 on: January 14, 2006, 10:00:18 PM »
ED
Not many mechanics out there are there.
elvin
« Last Edit: January 14, 2006, 10:00:18 PM by elvin1949 »
