Author Topic: Coffee can mill  (Read 2491 times)
Coffee can mill
« on: January 25, 2006, 05:08:30 AM »
       Gust up to 15-17 mph !!
I been kinda thinking about making a small
savonius one that would look real nice easy to
make...maybe cut a few plastic coffee cans in
half lengthways, put the tops together end to end
tape the seam together with some nice white
duct tape, so with that in mind...done that to
6 cans taped them together. Then should I overlap
them about 1/2 way?...just a 1/3 ? Put it on the
shelf for a couple of weeks ...months... then
yesterday or so fixed the neighbors little
ornamental windmill (3ft. on an 8 foot tower....
sitting out on his front lawn...
  I guess he only tied it down with one stake
   Spinning real nice and purty !
......Gee Whiz...I just gotta get somethin
spinnin !...I know ...I got those coffee cans
...that square pole doesn't have to be round..
I'll just take it, round the edges, paint it,
screw some bolts in the end going thru bearings,
screw some of those cans on the side of the pole
after I get it painted so everything will look
real nice....well that's how my day went....
planed the two square edges of the sawed in half
lengthwise 2x4, sanded it ....fantasy of a 2or3
kw mill..in everyonce in awhile for coffee and
warm up my feet....
   Neighbors little mill quit spinnin'
after the tower tipped over...(maybe he
should have had 2 stakes to hold it down ??)
  Well it was getting late so you know what
usually happens....slapped it all together....
put a little pin and screw in top and bottom
a la Picoturbine and it worked and took a pic of
it in the shed and wrote this post...so here 'tis
   Had it spinning about 200 rpm. planning on
using a front fork and bearings from a bicycle
to support it....then put it to work maybe charge
a 4 amp/hr battery to light up a few night
lights ?
   According to my combination water and sewer
bill if I had a windmill that could pump about
an average of 10 gal.of water an hr. I could save
$60 a month ...etc.
                   ( :>) Norm
BTW Cans represent about $40 or so worth of coffee.
« Last Edit: January 25, 2006, 05:08:30 AM by (unknown) »
terry5732
Re: Coffee can mill
« Reply #1 on: January 24, 2006, 10:12:21 PM »
The store brand is cheaper and not as bitter as Folgers.
I missed it - what were the white strips?
« Last Edit: January 24, 2006, 10:12:21 PM by terry5732 »
Re: Coffee can mill
« Reply #2 on: January 24, 2006, 11:00:51 PM »
white strips holds the cans together...white duct
tape....
                  (:>)Norm.
« Last Edit: January 24, 2006, 11:00:51 PM by Norm »
Re: Coffee can mill
« Reply #3 on: January 25, 2006, 06:49:06 AM »
What kinda generator are you gonna hook it up to ?
« Last Edit: January 25, 2006, 06:49:06 AM by wooferhound »
Re: Coffee can mill
« Reply #4 on: January 25, 2006, 08:14:05 AM »
Looks great!
It it spinning today?  Mine are frozen solid from last nights rain, and covered in morning snow.
I was told a primer called Zisser 'B.I.N' would stick to those cans, and allow painting.
« Last Edit: January 25, 2006, 08:14:05 AM by ghurd »
zap
  • There's an app for that
Re: Coffee can mill
« Reply #5 on: January 25, 2006, 09:40:07 AM »
Looks like fun Norm. If you had an old dowel or broom/shovel handle sitting around you could use that and offset every row under the 90 ­degrees you have now, making it look more like a helix and probably get more power out of it and also get away from any surges.
I put this up a few weeks ago to try and stop Zephyros and his nasty wind from blowing a solar collector off my roof. It's only held on with rope. We've had alot more wind than normal this year.
« Last Edit: January 25, 2006, 09:40:07 AM by zap »
Re: Coffee can mill
« Reply #6 on: January 25, 2006, 10:14:40 AM »
If the bike wheel is part of the device, some of that 'linked' type fan belt will ride where the tire was, making a very high speed output to a alternator pulley.
« Last Edit: January 25, 2006, 10:14:40 AM by ghurd »
Re: Coffee can mill
« Reply #7 on: January 25, 2006, 12:28:51 PM »
Norm;
   Nice look'n .
Humor me, take the stepper off that DC motor, hook this onto a bike wheel , use the rubber tire on the wheel to spin the DC motor and see what kinda output you get.
This is similar to what I am trying the find time to put together.
Drinking coffee like a trucker to save up the cans.
« Last Edit: January 25, 2006, 12:28:51 PM by Bruce S »
Re: Coffee can mill
« Reply #8 on: January 25, 2006, 04:24:52 PM »
  I have a few stepper motors that I got from
Ghurd...also a PM motor from Bruce S.
  I'll probably hook them to a bicycle wheel
to step up the ratio.
  Got the thought of that chain gear drive for
lower friction loss, as you'll see in my reply
to Bruce.
  Still got those ones hanging on your porch?
                ( :>) Norm.
« Last Edit: January 25, 2006, 04:24:52 PM by Norm »
Re: Coffee can mill
« Reply #9 on: January 25, 2006, 04:42:47 PM »
About a 20inch wheel ought to do it?
I'll be going out to round up the parts in a
little bit ...the other little steppers that
Ghurd gave me are  also likely candidates.
  Ever think of making a low friction chain
gear drive (notice I said chain gear drive? and not chain drive?)
  This is where the only sprocket is the driven
one....
  Tricky part getting the circumference for the
chain just right....hence the carboard template.
  Here is where you can have the sprocket pretty
loose....less friction.
  Well for now I'll just use the bicycle wheel....rubber band tensioner to hold the motor drum against the bike tire?
  Are you using plastic cans?
           Out of time for tonight a little more tomorrow.....
                ( ;>) Norm.
« Last Edit: January 25, 2006, 04:42:47 PM by Norm »
pyrocasto
Re: Coffee can mill
« Reply #10 on: January 25, 2006, 05:54:33 PM »
I just built that exact mill today. :-)
« Last Edit: January 25, 2006, 05:54:33 PM by pyrocasto »
RobD
Re: Coffee can mill
« Reply #11 on: January 25, 2006, 06:20:40 PM »
I'm wondering if you would get better torque with the mags spaced 45 degrees instead of 90.
RobD
« Last Edit: January 25, 2006, 06:20:40 PM by RobD »
Re: Coffee can mill
« Reply #12 on: January 25, 2006, 08:15:59 PM »
Well ,  I've moved since I made the picture.
But I have it hanging on the side of my wifes greenhouse. It's always spinning.
« Last Edit: January 25, 2006, 08:15:59 PM by wooferhound »
zap
Re: Coffee can mill
« Reply #13 on: January 25, 2006, 11:15:35 PM »
ghurd the bike wheel is only loaning it's axle to the project for now so this is just a spinner so far.
They sure are easy mills eh Chris? This one is a 50% overlap and I have the plywood cut for a 25% overlap, just need to cut and mount the buckets so I can do a side by side comparison. It sure goes against the grain though, cutting a perfectly good bucket in half!
Sorry Norm... didn't mean to take away from your post.
« Last Edit: January 25, 2006, 11:15:35 PM by zap »
Re: Coffee can mill
« Reply #14 on: January 26, 2006, 07:03:35 AM »
  That's ok zap....listening and learning.
  Bicycle wheels are good for the bearings or
the rim but no powershaft unless you want to take
power from the rim.
  I did make my own hubs with 1/2 inch shaft at
one time but that's another story ...after awhile a person can get quite good at respoking bicycle wheels......
                later....
               ( :>) Norm
« Last Edit: January 26, 2006, 07:03:35 AM by Norm »
Re: Coffee can mill
« Reply #15 on: January 26, 2006, 12:12:34 PM »
 Bruce, Working on respoking a 20 inch bicycle
wheel to a square-holed hub to fit the shaft of
the coffee can mill.....
          I'm off to do it....hopefully it'll
only take the rest of the day ...LOL !
                  ( :>) Norm.
« Last Edit: January 26, 2006, 12:12:34 PM by Norm »
Re: Coffee can mill
« Reply #16 on: January 26, 2006, 12:40:08 PM »
 Still like the looks of it...maybe one of these
days when you run out of things to do ...you'll
hook a real small genny to it.
 I've got a pinwheel with little leds that light
up on the tips when it spins...It sold for $10
originally and I figured it just had a little
button battery to light it up thru a centrifugal
switch...so no way I was going to pay $10 for one
....the price went down to $4.95...still no sale
for me!.....but then it dropped to 69 cents...
now you're talking...but when I got it home it
wouldn't work...so I took it apart and it is a
minature altenator with a stationary round magnet
with a hole, like a microwave magnet....then it
has a metal disk on each side with points like a
star, the points fold over the edge of the
magnet giving about 6n and 6s poles the stator
is in the hub of the pinwheel ...a coil and a
led for each blade of the pinwheel...so if you
got a microwave or donut magnet and some leds
and some wire...you'd be all set ....would look
purty at night ??
                  ( :>) Norm.
« Last Edit: January 26, 2006, 12:40:08 PM by Norm »
Re: Coffee can mill
« Reply #17 on: February 09, 2006, 03:54:52 PM »
Did you get it generating?
We had some stiff breeze here, naturely from the wrong direction.
« Last Edit: February 09, 2006, 03:54:52 PM by ghurd »
