Author Topic: vawt do work for some things  (Read 1211 times)
wildbill
« on: April 14, 2009, 05:12:59 PM »
« Last Edit: April 14, 2009, 05:12:59 PM by (unknown) »
wildbill
Re: vawt do work for some things
« Reply #1 on: April 14, 2009, 11:31:41 AM »
pict. was taken in Jan. in northern wis. (we do get cold -20 deg.)but the wind
turbin worked good, even tho i nocked two of thefloats lose lubing the saft sleave
with used peanut oil. hole stayed open until feb.20/th. then it needed help
a little ice chissel, but i don't have floating fish.
« Last Edit: April 14, 2009, 11:31:41 AM by wildbill »
« Reply #2 on: April 14, 2009, 11:58:33 AM »
bill;
I have seen these used before in 2 styles. One is a simple water agitator / beater. The other is a low pressure, high volume air pump. Seems anything that can make the surface move keeps a hole ice free.
Looks like a perfect application of the low speed and high torque these have.
The open hole really improve fish survival up here where it can get freaking cold. Some shallow ponds freeze right to the bottom.
Good luck with it.
« Last Edit: April 14, 2009, 11:58:33 AM by TomW »
« Reply #3 on: April 14, 2009, 12:17:06 PM »
Cool!
I am guessing that has a fan blade under there somewhere?
And mostly just stirring the upper layer of water?
Might put the fan blade in a long pipe.
Bring some of the deeper warmer water to the surface.
Maybe a suitable size pipe for the fan, and some sump pump hose for the drop?
Looked like it would work well, but the project fell apart for other reasons.
It will help in summer with getting nitrogen, ammonia, etc
to the surface for natural dissipation,
and O2 down deeper.
« Last Edit: April 14, 2009, 12:17:06 PM by ghurd »
wildbill
« Reply #4 on: April 16, 2009, 07:07:24 AM »
G
I do have a 12" pvc pipe down about 6" from the pond bottem and a 10" prop inside
connected to the shaft. now that the ice is out i have to go and fix the floats.
thanks for looking.bill
« Last Edit: April 16, 2009, 07:07:24 AM by wildbill »
