grateful for your reply
thought "iron core" was better...... why else try the band saw blade in the volvo homebrew??
as to already been done........... havent seen the guys try using ONE rotor BETWEEN two "stator packs" loaded with coils? but i might have missed something.
think about it.....in EVERY design...HALF the magnetic flux is sucked up against a chunk of metal, doing.....NOTHING!
why not spin ONE rotor BETWEEN two stator packs? then BOTH sides of the magnet produce "juice".
HOW??? well increase the design of the the two-inch round aluminum stator "stencil" that sells for $28....... by 2 inch or so....... and increase thickness by at-least double if not by factor of 3....so it can handle the stress of the magnets wanting to "fly away.
double the magnetic flux lines cutting through coils, with LESS rotor weight....talk about low speed performance???
THINK about the design of the latest 17 ft beauty.... a true work of aart....but it has 4 faces of magnets and only 2 produce power....the other 2 do what?
FULLY REVERSE the design...make the "rotors" into fixed coil loaded stators and spin ther single dual sided rotor between them.
use ALL the magent to produce power?
isnt that efficient?
how do i get that idea to the guys?
Mark
