Author Topic: Amp meter  (Read 870 times)
Shadow
Amp meter
« on: April 28, 2005, 06:47:17 AM »
Will this digital amp meter work for my Dual rotor 48 volt wind turbine?..Or am I wasting my money? EbaY Link
« Last Edit: April 28, 2005, 06:47:17 AM by (unknown) »
GBillerty
Re: Amp meter
« Reply #1 on: April 28, 2005, 05:51:49 AM »
This should work if your windmill saty under the ampmeter's maximum amps.
This ampmeter looks nice
« Last Edit: April 28, 2005, 05:51:49 AM by (unknown) »
wpowokal
Re: Amp meter
« Reply #2 on: April 28, 2005, 06:01:38 AM »
This looks lonley so....
Yes it will, DC amps through the shunt is amps, assuming the shunt output is matched to the digital metre it will work.
You will need a regulated 5V DC power supply,  that may not be able to share a common ground, my LED metre can. Read the instructions well, also LED metres use much more power than LCD but have the advantage of being able to be seen in the dark, oh and they also are a great nite light.
allan
« Last Edit: April 28, 2005, 06:01:38 AM by (unknown) »
