From my earlyer post you see the small wind farm. I was wrong the small building only has 3 machines on it. The 2 behind are on a larger shop to the rear.
Here are so test #s from some wind generators a couple weeks ago. These #s are prety typical. Units being tested are Garbogen, Wind Blue 540, Wind Blue 540 with my blades "Jerry Riged" 6 wire down the tower and my home built car alt with a factory Delco 24 volt stator Jerry Rigged 6 wire down the tower and a 7 blade prop. This last unit is configured with 3 large caps and the 3 bridges wired in sires.
