Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Wind
Info regarding Jacobs 1800W
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Info regarding Jacobs 1800W (Read 2405 times)
Homesteader1
Newbie
Country:
on:
February 04, 2015, 08:14:51 PM »
Hi Everyone.
My name is Dale and I'm relatively new to this forum. I'm in the process of a complete restoration of a Jacobs Model 18 1800W, 32V machine. I will post a complete photo journal of my work if anyone is interested. I'm presently rebuilding the prop governor and I have remove the inner and outer prop shaft bearings. My machine appears to be in excellent shape for such an old machine. I know that many of these beautiful machines was shipped with tapered roller bearings on the prop shafts but mine has double row ball bearings. The outer bearing is a Nice (mfr) 1216-41 and the inner is a Nice 1210-30. I want to replace all 6 bearings with similar ones although I don't care who the manufacturer is. My problem is that the bearing is an obsolete number and after many calls to bearing houses and an internet search I can't find a modern replacement. Does anyone have a modern bearing part number? Any help would be greatly appreciated.
Regards
Dale
Logged
Harold in CR
Hero Member
Re: Info regarding Jacobs 1800W
Reply #1 on:
February 04, 2015, 08:44:46 PM »
Do you have dial or digital calipers, to measure ID and OD / Then, you can match something up.
I had to do this a couple of times, in the past, and, it worked out fine.
Harold
Logged
Global Moderator
Super Hero Member Plus
Country:
Reply #2 on:
February 04, 2015, 08:58:39 PM »
A few years ago, a fellow rebuilt a Jake, and posted many photos of the process here.
I will look up the old thread for you. He may have addressed the bearing replacement issue too.
Logged
Global Moderator
Country:
Reply #3 on:
February 04, 2015, 09:04:08 PM »
Tom Sullivan's project:
http://www.fieldlines.com/index.php/topic,143812.0.html
http://www.fieldlines.com/index.php/topic,147323.0.html
http://www.fieldlines.com/index.php/topic,144650.0.html
You can do your own search on the forum and find a number of other Jacobs projects and questions.
Logged
Hero Member
Country:
Reply #4 on:
February 04, 2015, 09:40:57 PM »
this guy has one of the bearings you need.
http://www.richardscompany.com/Nice_Inv.htm
here is the other one:
http://www.amazon.com/Nice-1216-41-Unground-Ball-Bearing/dp/B00DBNV7VE
make sure you set the preload correctly or they won't last long.
Logged
SuperHero Member
Reply #5 on:
February 04, 2015, 09:43:32 PM »
Amazon and eBay sell the bearing new in box
http://www.ebay.com/itm/1216-41-NICE-New-Unground-Ball-Bearing-/151574643941?pt=LH_DefaultDomain_0&hash=item234a8d84e5
http://www.ebay.com/itm/1210KJ30-SNR-New-Self-Aligning-Ball-Bearing-/151574643265?pt=LH_DefaultDomain_0&hash=item234a8d8241
Logged
Homesteader1
Newbie
Country:
Reply #6 on:
February 05, 2015, 03:32:51 PM »
Thanks to everyone who offered advise. I ended up getting the 1210-30's from Richard's and the 1216-41's from LocateballBearings.com. The ones that are on ebay that are self aligning are not the correct ones. The have the same part number but are totally different. The guy at Richards commented that these are definitely old bearings and the only way to find them would be to find someone with NOS ones available. Anyway, problem solved. Many thanks!
Daele
Logged
Print
Pages: [
1
Go Up
« previous
next »
Wind
