Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
New Project Newbie
Gas powered AIR-X
Not Home built but this is my new turbine.
Dans 17'
Question about small magnets.
New VAWT
Calculating ZubWoofers
Chinese manufactured blades
Ebay Small Wind system
Other Power wind parts specs.
Wind installs pass 10,000 Megawatts
Triple Rotor / Double Stator?
First wind turbine: I need a bit of advice
A question for DanB
Coils
is this motor worth converting 25hp dayton
new to wind energy
Trying to find what my vawt is doing
Reducing wear on wind generator
Chinese VAWT's
Measuring power output
Coils - Wound w/out Splices
Vertical Axis Design - your opinions?
composite blades, used in water?
Data logger
axial flux applications
would like 75W (12V) @ 11MPH, is that ok/possible?
DanB's 17ft Machine
windmill noise
Windmill design for a 20-30 HP 3 Phase Motor
Tape drive motor
Lenz Turbine
Volts per Coil
Laminating wood
Efficiency
A question for DanB
12v vacume motors for wind generators?
I'm test flying
Vail Resorts to use wind power
Maybe a Conversion
Question about rotor?
Doubling wire question
Sanity check on load balancing..
Dead ametek?
Piggots 2 foot radius prop blades
BIG Wind generator start
Fisher & Paykel
Wind turbines in freezing weather
Ametek motor magnets
Is This Charge Controller Any Good?
