OK. I posted (or attempted to post) something earlier but "Vista" totally sucks. Crashes every 5 minutes.
Under "I wouldn't over complicate it."
I think I said something like "Don't be discouraged" and "If it takes a lot of effort, time, money, then spend an extra day and a few extra $ to make a small quickie motor conversion to get 5 to 100X more 12V battery charging power".
I believe anything 'normal' under 30" dia needs 4" or 6" PVC. 24" seems better with 4". It depends on who did what with what.
And I don't like the issues involved with PVC blades over 24".
"I've used the 0 to 25 degree rule when measuring for width."
Uh, What? ("Vista" so no time to look)
I use "Zub-Woofers" measurements for PVC. I tried changing stuff but the results were not good. The blade plans...
http://www.fieldlines.com/story/2005/4/19/161431/811
The Volts on anything/everything top out at the battery level. (the gen can't be 50V, with a 0.7V diode drop, into a 12.6V battery)
The Amps of a stepper top out at a certain RPM level. (if it makes 100ma into a 12V battery at 1000RPM, it might only make 110ma into a 12V battery at 2500RPM)
It's not the same, but it seems you are beginning to understand that.
The bottleneck is the resistance, among the other things Mr. Flux listed.
"interesting substitute for a solar path light".
Check out Claude's stepper windmill nightlight...
http://www.fieldlines.com/story/2006/10/10/212737/59
It's your thread. My understanding is you can take it wherever you like, because as related to the main thread, it keeps everything in one place, and the off topic stuff is related to what you want to know.
