Walter, there is thin wall conduit and heavy wall conduit. Heavy wall would work just fine. It would however put out toxic fumes when welded, but I do it all the time, just make sure your outside, and have the wind blow the smoke away from you. 4 inch heavy wall condiut, measures 4 inches on the outside dia, so it works great for sliping inside of 4 inch scedule 40 to make a stronger joint when welding pipe sections together. If you have the choice, I would use steel pipe!!
