Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Recycled Plastic Lumber for Blades
WindMax 9.2 Blades on 10 Footer
12 ft coil wire
Hornet wind tunnel test.
Blade Design
Choices on coil configuration
thoughts on freestanding tower
A nice summer's cloudy windy day
ac motor conversion?
coil size vs # of turns
New Alternator Idea
Windy-Boy Piggy-back connector
1mm wire max amps?
Cable Tension Gauge
calculating voltage of test coil
10' Turbine Rectifier Parts Questions
Test tower for my 20ft genny
First wind tunnel test.
guy-gin pole attachment?
Hugh Piggotts 4 Ft prop alternator performance?
2X1X1 inch magnets - Too big for 10' axial?
Midwest Renewable Energy Fair 2009
Small Wind Research
Hey Woof ?
Substitute for resin?
turbine for grid connection
using magnet wire from motor stator
New Aurora Wind Inverter
17' 3D blade drawings
Axial Flux Generator Troubleshooting[Duplicate CLOSED]
Furling With and Without Loads
specific info
Need help hooking up air compressor to rotor
Axial Flux Alternator Wind Turbine Lowering
Electronic braking
Wind turbine tower
Garbogen
cs130 delco alternator
a turbine off the bickleton highway??
question about ecm's
1st Electric Bill after Genny Flying
Outside Mag Pic George, Dan, Rich
Single phase Aurora Inverter help.
PIcked up a servo motor
Tower anchor size ?
Could I make suitable wind turbine blades out of these??
War of the turbines
my 2 wind turbines under negative effect
Battery Question
Required Genrator RPM - Volts or Amps
