Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Actual Logged data and Graphs 12ft machine
Suburban and Urban A/E Systems...
ECM 1/2 inch shaft to 1 1/4" collar
35 foot tilt up tower design
11 footer, round 2in magnets, need coil help
stall controlled downwind?
turbulance
new blade test with PM treadmill motor
Wind turbine stator coils question
Tower Construction
A bit wary about shorting out
china neo mag update
The importance of steel around the magnet?
Blade design thread- The payoff & thanks!
Need a winch for my turbine
Skystream 3.7
Dakar ~ should be interesting
Rho calculation adjustment for altitude
ametek blades
Frustration has set in...new install
Changing voltage of 12' Home Brew?
My turbine power wall
Generator completed but hard to turn...
dump load
UK wind worry
walp DIY 3.49m wind power generator project
10' turbine Rectifier help?
Countersunk holes in magnets
12' Turbine install
Cooling loop in a winding.
Newbie, new windmill (Satillite Dish) design
Thickness and number of windings for 12 or 24 volt 17 foot wind turbines?
Up and running, turbulence question
Any discussion of using hydraulics to power PMG's
Tower for 20 footer
20 foot, Grid Tie PMG, no batteries, maybe found the answer.
Ghurd has good idea.
Question for GHurd , new ECM
Wind to Heat
angle grinder reductuon gear
MOVED: MPPT for commercial wind turbines
Micro Turbine
Air Conditoner Disconnects
Two Days of Relentless Wind
Need some help to choose right cut in parameters
Humming noise at cut in
Rooftop wind doesnt work
MOVED: Anhui Hummer Wind Turbine - Fraud Specifications
modified micro wind turbine
Noise level numbers Piggott design
