Author Topic: somewhat confused  (Read 2799 times)
mjc2002
somewhat confused
« on: May 19, 2008, 12:47:15 PM »
i have several stupid questions:
  1. on the pre-cast stators sold for $225-$245...i see only three connections, where are the other three? each coil has two ends, there are three phases, so the brass bolts are one end of each phase, where is the other connection of each phase?
  2. why are the coils "air core"? wouldn't powdered ferrite mixed with epoxy and poured into the center of each loop be better and produce more?
  3. and lastly i guess somewhat belayed.....if someone contributes to the design: adding efficiency; or lowering costs per kilowatt; or some vast improvement....would this person be rewarded in some way? or should they seek to patent the improvement first?
Mark
« Last Edit: May 19, 2008, 12:47:15 PM by (unknown) »
finnsawyer
Re: somewhat confused
« Reply #1 on: May 19, 2008, 07:05:50 AM »
  1.  The other three wires are connected together to make the "star".  Probably not a good idea as those ends end up being hidden and make Jerry rigging impossible.
  2.  Air core has no "cogging" effect.  Your suggestion would to some degree or another.  One could also insert screws from the backside of the stator to whatever depth desired to increase the flux.
  3.  If you want to know how new ideas are treated, read this:
     http://www.fieldlines.com/story/2006/4/21/16237/9933
As far as the patent, how deep are your pockets?
« Last Edit: May 19, 2008, 07:05:50 AM by finnsawyer »
« Reply #2 on: May 19, 2008, 07:12:30 AM »
 #1,
http://www.fieldlines.com/story/2003/9/11/84741/6758
 #2, Iron losses, cogging, cost & complexity, and probably less effective per dollar.
 #3, I feel pretty safe saying "It's already been done".  And recoving that $50,000 spent on a patent will make the machine expensive enough to be expensive.
« Last Edit: May 19, 2008, 07:12:30 AM by ghurd »
« Reply #3 on: May 19, 2008, 10:19:01 AM »
mjc;
First, I must ask. Did you read here for even 5 minutes before posting? I didn't think so.
DanB keeps a tally of helpful ideas and sends bonus checks regularly to those he feels deserve it. I hear flux will be retiring in Barbados on his bonuses [or should be].
Our reward comes from having helped be part of a solution rather than just another part of the problem.
Patents are evil, senseless things that will draw my ire any time they are sought.
Its a new world coming on. Personally, I am beginning to think all new users should pay a fee to even read the board. After all, I have thousands of hours and probably millions of my words invested here and I seldom [never] have seen a dividend check.
Ok thats a joke but should illuminate my point.
Good day, sir.
« Last Edit: May 19, 2008, 10:19:01 AM by TomW »
mjc2002
« Reply #4 on: May 19, 2008, 03:30:42 PM »
didnt mean to offend
i also fear the fate of paul pantone myself
i will expound on my question later
thank you for the reply
« Last Edit: May 19, 2008, 03:30:42 PM by mjc2002 »
mjc2002
« Reply #5 on: May 19, 2008, 11:01:30 PM »
grateful for your reply
thought "iron core" was better...... why else try the band saw blade in the volvo homebrew????????
as to already been done........... havent seen the guys try using ONE rotor BETWEEN two "stator packs" loaded with coils???? but i might have missed something.
think about it.....in EVERY design...HALF the magnetic flux is  sucked up against a chunk of metal, doing.....NOTHING!
why not spin ONE rotor  BETWEEN two stator packs? then BOTH sides of the magnet produce "juice".
HOW???  well increase the design of the the  two-inch round aluminum stator "stencil" that sells for $28....... by 2 inch or so....... and increase thickness by at-least double if not by factor of 3....so it can handle the stress of the magnets wanting to "fly away.
double the magnetic flux lines cutting through coils, with LESS rotor weight....talk about low speed performance?????????
THINK about the design of the latest 17 ft beauty.... a true work of aart....but it has 4 faces of magnets and only 2 produce power....the other 2 do what?
FULLY REVERSE the design...make the "rotors" into fixed coil loaded stators and spin ther single dual sided rotor between them.
use ALL the magent to produce power???????
isnt that efficient?
how do i get that idea to the guys?
Mark
« Last Edit: May 19, 2008, 11:01:30 PM by mjc2002 »
Capt Slog
« Reply #6 on: May 20, 2008, 01:49:15 AM »
On the subject of offence....
Are those two danasoft.com banners at the bottom of your posts really necessary?
« Last Edit: May 20, 2008, 01:49:15 AM by Capt Slog »
mjc2002
« Reply #7 on: May 20, 2008, 06:52:08 AM »
unknown what the problem was but..............................................
« Last Edit: May 20, 2008, 06:52:08 AM by mjc2002 »
« Reply #8 on: May 20, 2008, 07:10:18 AM »
most of the things you are suggesting have been tried and discarded .
if you wish to study and find out why
google search the board and find out why.
« Last Edit: May 20, 2008, 07:10:18 AM by electrondady1 »
« Reply #9 on: May 20, 2008, 07:19:53 AM »
Cap;
No they are not necessary or acceptable. As soon as I saw them I removed them from the .sig and it looks like the user edited his .sig, too.
I see those a lot and find them 100% offensive and what is much worse, invasive. Just another way to sucker regular folks into helping track the activities of others as you know they archive and sort / sell the data.
You can protect from them by redirecting DNS lookups to 127.0.0.1 in your computers "hosts" file. Just add this line:
127.0.0.1 www.danasoft.com
Next time you boot up the danasoft domain cannot be found so those annoying .sigs will just be broken. Aww gee.
No worries, its gone now.
« Last Edit: May 20, 2008, 07:19:53 AM by TomW »
« Reply #10 on: May 20, 2008, 07:31:21 AM »
I guess "harmless" is in the eye of the beholder. Those things are obnoxious, invasive, useless and, as far as I am concerned banned on this forum.
Anyone thats been online more than overnite should be aware of the fact that they mark you as having visited sites and the arse hats at danasoft sell that info that you so gullibly gathered for them.
They will not be tolerated, regardless of who thinks they are "harmless".
I do not think this is negotiable but you may ask DanB for an opinion if you feel the need to do it.
« Last Edit: May 20, 2008, 07:31:21 AM by TomW »
finnsawyer
« Reply #11 on: May 20, 2008, 08:49:05 AM »
"havent seen the guys try using ONE rotor BETWEEN two "stator packs" loaded with coils???? but i might have missed something."
It's been considered.  It's not a particularly good idea, and this comment shows your lack of understanding of what a flux path means and does.  The iron behind the magnet, rather than doing nothing, actually enhances the flux through the air where the coil resides.  This has to do with a property of iron called the magnetic reluctance, which is sort of like resistance, but applies to magnetic flux rather than current.  The greater the reluctance of a material (or space- space exhibits reluctance too) the less the magnetic flux density and the less the flux passing through a given area.  The upshot is that the reluctance of air or space is about 1,000 times higher than that of the iron for the same path length.  With two stators you have doubled the reluctance of the air parts of the flux path.  This means half the flux or half the voltage per stator as the reluctance of the iron parts would not be affected as long as you did use the same iron parts.  Combining the outputs of the two stators, you would then get the same voltage as with the single stator.  Aside from the fact the you have doubled your work you also have doubled the resistance of each phase winding.  The result is less power.  This is a simplified explanation, and you should spend some time researching it on your own.
« Last Edit: May 20, 2008, 08:49:05 AM by finnsawyer »
fungus
« Reply #12 on: May 20, 2008, 08:55:03 AM »
"You can protect from them by redirecting DNS lookups to 127.0.0.1 in your computers "hosts" file. Just add this line:"
Ubuntu etc also have a hosts.deny file too - so you just put in ALL: danasoft.com for example ..
« Last Edit: May 20, 2008, 08:55:03 AM by fungus »
mjc2002
« Reply #13 on: May 20, 2008, 12:47:04 PM »
i did search it out at your suggestion....thank you.
EVERY one that involves a dual stator STILL wastes flux.... for example
http://www.fieldlines.com/story/2007/7/14/442/09914
magnet stator magnet stator magent
those two outside magnets arent  MONO poles of course....so two poles are wasted
didnt see a suggestion to mount ONE magnet rotor between two stators that diidnyt involve wasting two poles
magnets are two sided...why not use BOTH sides of a single magnet to create "juice"
but obviously i am no expert
thanks
« Last Edit: May 20, 2008, 12:47:04 PM by mjc2002 »
mjc2002
« Reply #14 on: May 20, 2008, 12:52:21 PM »
i have seen where there is a suggestion to connect the stators in series
why? that increases resistance as you say
why not rectify and add in paralell?
if the north pole is cutting through a coil..what good does it do to have the south pole of the same magnet just stuck to a iron rod
like taking two buckets to the river
and only filling one??
thanks
« Last Edit: May 20, 2008, 12:52:21 PM by mjc2002 »
mjc2002
« Reply #15 on: May 20, 2008, 01:10:08 PM »
I am totally confident in my lack of both knowledge and understanding
thats why i ask questions
you see, he who askes the question is a fool for five minutes....until he gets the answer he sought
he  who refuses to ask and gain knowledge......is a fool forever.......
God bless the unknowing....un-pompus...un-informed
God bless those that fail
Edison comes to mind
i am no edison that is for sure....but i only have UP to go
those full of pride and self-love
have only DOWN to look forward to in the end.
« Last Edit: May 20, 2008, 01:10:08 PM by mjc2002 »
fungus
« Reply #16 on: May 20, 2008, 02:56:03 PM »
I think a fatal flaw in your understanding is what 'happens' to the other pole. Magnets emit flux lines which permeate through materials, when you have an iron backing on a magnet it redirects these flux lines forwards and boosts the density in the gap, so it isnt 'wasted'.
« Last Edit: May 20, 2008, 02:56:03 PM by fungus »
« Reply #17 on: May 20, 2008, 04:56:39 PM »
When magnets are stuck to iron, the flux is channeled through the iron which amplifies the strength of the magnets. You will not feel any magnetism on the backside of the iron because the magnetism is being channeled to the other magnets on the iron plate.
Here is a picture of what I'm talking about
The magnetism from the back of the magnet is not wasted, just redirected for better strength
« Last Edit: May 20, 2008, 04:56:39 PM by wooferhound »
« Reply #18 on: May 20, 2008, 09:25:57 PM »
One,
http://www.fieldlines.com/story/2004/12/2/5455/05495
You are confusing "wasting" with 'redirecting'.
« Last Edit: May 20, 2008, 09:25:57 PM by ghurd »
finnsawyer
« Reply #19 on: May 21, 2008, 09:02:51 AM »
You are aware, of course, that an electromagnet acts just like a permanent magnet, producing both a magnetic field and magnetic flux.  Well, I would like you to show where the flux is wasted in a transformer.  You know, those things that transform ac from say 120 volts down to 12.6 volts or up, as the case might be.
« Last Edit: May 21, 2008, 09:02:51 AM by finnsawyer »
Capt Slog
« Reply #20 on: May 22, 2008, 07:48:57 AM »
Sometimes a fool only wants to listen to the 'answer he sought' and has yet to realise that there's no point in asking the question if he is going to disbelieve the answer because it doesn't confirm his misconceptions.
« Last Edit: May 22, 2008, 07:48:57 AM by Capt Slog »
mjc2002
« Reply #21 on: May 30, 2008, 06:51:27 AM »
thanks fr the info, visual helps incredibly. also another thread i read helped explain why AC is preferred over dc. i really appreciate the help you have given me to understand
« Last Edit: May 30, 2008, 06:51:27 AM by mjc2002 »
mjc2002
« Reply #22 on: May 30, 2008, 06:55:09 AM »
a flaw indeed.........thanks for the explination, increases my understanding of this and my own stupidity
i think i had ONE helpful suggestion
use high gloss, oil based "spar varnish" aka gym floor finish on the blades
« Last Edit: May 30, 2008, 06:55:09 AM by mjc2002 »
TheCasualTraveler
« Reply #23 on: May 30, 2008, 01:16:27 PM »
     Good job Finn, Ghurd and Woof. Those were some very straight forward and easy to follow answers, from a newcomers point of view. Woofer, a bit of cutting and pasting of this post with diagrams might go well in a FAQ.
« Last Edit: May 30, 2008, 01:16:27 PM by TheCasualTraveler »
mjc2002
« Reply #24 on: May 31, 2008, 09:58:54 PM »
Great work to say the least! wonderful to have them "sahre the wealth" of knowledge the have and not just suggest someone find the answers on thier own. with a few little keystrokes i have become educated beyond my expectations.... this is an honest heart-felt thank you....i hope they see it.... they are a treasure to the board
Mark
« Last Edit: May 31, 2008, 09:58:54 PM by mjc2002 »
