Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Homebrew beats the store -bought junk any day!
SlipRings - DIY Ball Bearings with AC
Scored a treadmill, questions about the motor
anyone have DC Motor Analyzer software
Windmax 1KW Update
Restricting turbines maximum speed
Resistors as dump load, is it efficient?
Blade question
HV alternator ?'s
does ametek 38vdc need to be geared
Bettery not charging
ac servo motor help
Shunt wound generator.
Help with 5 kw manchine
New Mexico (Tusas) tower erection
"Shifting gears" to regulate wind turbine output
dummy load problem,please help
Good motor?
Should be flying this weekend!!!
South Dakota, Novice Wind Turbine Development
3/4 ecm Finally.
Gyro Turbine
Tell me how to buid a simple slipring
Almost There -- Tower is in place...
How to determine overall system efficiency
10.6 foot windmax blade report
GRP blades for Otherpower 10'
CAD Drawings for 17ft Turbine
Help with motor for wind turbine
Resistor in line from windgen to regulator?
high solidity and sensitivity to wind changes
Magnet Plate Casting - What Are We Doing Wrong?
Shunt not halting alternator
1 KW turbine strapped to a bungalow??
Blade Size?
this may be it!
Garbage Turbine #4
Tail furling without load.
How to calculate windings to resistive load.
Cutin and TSR/pitch considerations for MPPT controller
Coloring resin for stator casting
40' Tilt-Tower Design
Not sure if I want to buy or build???
Good wind in texas!
my little project
WT Collapses in USA
Anyone use 1/2 inch Neo 42 Grade Wedge Magnets?
Printer motor turbine
chinese 300w 24v turbine blades ...how to make less noise?
axial flux generator design
