Homebrewed Electricity
» Wind
View full version:
Wind
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
Another new 12 foot diameter turbine
stator with lamination sheets
Loading?
Christmas Eve Winds
Attributes of combined wire
Magnets arranged in a circle vs radial pattern ?
wind/solar powered semi truck concept
iSTA-BREEZE I-1500
My Website for Wind Turbines
First build
Voltage generation in a coil
Reducing cost of magnet wire
Recovering magnet wires?!?
"700 watt" eBay wind turbine
13' Induction Motor Conversion
wire straightner?!?
question about load and ease of spin
Caps
Help needed with stator rewinding of 36pole LG smartdrive motors.
Baby Blue Motor Conversion
Report KD 708 about a 22-pole PM-generator available
Report KD 707 about the generator TGET380-10KW-1200R available
Resistance of materials?
WindTAC controller - practical experiences wanted
Testing a three phase rectifier
Magnet Density?!
bobbin building......
Clockwise or Counterclockwise
Report KD 705 about the generator TGET320-1KW-350R available
Hoverboard motors!
report KD 702 about the VIRYA-0.54 rotor available
Can you run two rectifiers on one turbine?
Using a micro solar grid tie inverter with wind turbines
Samsung direct drive motor
Maximum efficiency of an axial flux PMA?
Tornado Viewed from Underneath
Coil alignment
Wind Generator with Hard Drive Magnets
Magnet orientation based on topology
Hoverboard motor output questions
Low Speed PM Alternators
scrounged parts
Servicing 3off Hugh Piggott design 3.7m, 12ft diameter Wind Tturbines
Energy Pole by G Labs
Bryan's Wind Genny about to turn again
400w eBay turbine #2
New Blades for Spirit of Zubbly
Help with a hybrid powered security light pole thing!
Anyone dealt with "Hurricane" wind turbines?
Rectifier vs diodes
